Like Tree195Likes
Novarossi engines thread
Old 08-03-2017 | 02:04 AM
  #5341
mustangkillaz's Avatar
Originally Posted by dan_vector
If you are worried just fit one of the new 2017 rods. Mind you I've never had a Novarossi conrod fail in any of my.21s both on and offroad. R7's and R4's.
Good to hear. I'll run mine until it breaks or I feel it's time.
mustangkillaz is offline
Old 08-03-2017 | 02:39 AM
  #5342
dan_vector's Avatar
Well to be fair you do need to change rods a little more often! I usually change after the first 2 gallons and then every 4-5 gallons thereafter. Waiting until it breaks is usually a little bit late...
davidl likes this.
dan_vector is offline
Old 08-04-2017 | 12:31 AM
  #5343
That's not bad. I'll change it on over revved motors and heavy stop n go raced motors much more sooner than later. On regular bashers or speed run cars, I don't find it needed as much. Your interval is a safe bet, though. I'm doing some testing and will not change rods on a couple of my motors until they break. I wanna get an idea on what kind of life the rod will do.
Old 08-10-2017 | 09:46 AM
  #5344
I have not paid less for less performance. The new engine are awesome great performance
dan_vector likes this.
wichitafc98 is offline
Old 08-11-2017 | 04:26 AM
  #5345
Hi,
i just started racing nitro 1/10 again and have some questions.
i run a TOP T-PLUS 12-3 engine.
The rod that is recommended for the engine is 07604/1, would rod 07604 work? My favorite website only sells 07604.
And then the bearings, im running steal bearings and what is the estimated run time? every 1 gallon? i read in the tread that i just should "feel" the bearings, but i just dont have the experience that is required.
Im sorry if these questions have come up before but this thread is really big.
love my nova
ashori is offline
Old 08-11-2017 | 06:13 AM
  #5346
dan_vector's Avatar
Originally Posted by ashori
Hi,
love my nova
The 07604 will work just fine in your engine.
As for bearings you'll notice when the bearings are going because the engine will start to become difficult to tune, Idle and will also sound different almost rattly. Novarossi steel bearings will last a very long time if you are using a very good castor blended fuel. If you want you can change bearings once for every 2 conrod changes.
Old 08-12-2017 | 04:59 AM
  #5347
Thank you!
ashori is offline
Old 08-14-2017 | 06:44 AM
  #5348
BigC2007's Avatar
Default Carburetor Question ?
Are there any difference in novarossi carburetor from one engine to the next ? ( mostly .21)
Are there any improvements for the newer 2017 engines ?
BigC2007 is offline
Old 08-14-2017 | 09:30 AM
  #5349
dan_vector's Avatar
Yes there are. Currently I believe there are 3 onroad carbs available. Some double adjustment and some triple adjustment.
Improvements to just the 2017 carbs or do you mean the engines complete? The latest 21 Mito WC engines have new R4'17 rods which are made from a new stronger material. The Mito 5GT 21 has a new liner which is basically a 7 port liner with the 2 ports each side opened out into 1 square port making it a 5 port liner and supposed to generate more torque.
Old 08-14-2017 | 09:46 AM
  #5350
BigC2007's Avatar
Thanks Dan for your knowledge, I was just wondering on the carbs alone if for 2017 if there were any differences from 2016's and 2015's. I was reading that another company was talking about they new carb for 2017 that was an improvement with better fuel time and easier turning.
I dont know to much about the 2 and 3 screws carb adjusting if one if better then the other. I have to do some troubleshooting with my PTA Tuned Flash that I have it seems not to hold a tune when running for more then 10 mins.
BigC2007 is offline
Old 08-14-2017 | 09:51 AM
  #5351
dan_vector's Avatar
I think the Novarossi carbs have remained fairly constant in the last few years. The main changes are usually to the spray bar length and bottom needle length. The carb throat is the same for the flash as the latest engines.
Have you changed the orings in the Carb on the flash? The carb could be drawing in air when it gets hot. You can also look at bearings in the engine that can cause havoc with engine consistency.
Old 08-14-2017 | 10:01 AM
  #5352
BigC2007's Avatar
Wow Dan thanks for this info, I was try replacing the o-rings to see if this helps out. No to worried about it because I am still looking forward into picking up The full hand modified and pre-ran in Ielasi Nitro.21 WCE 2017.
BigC2007 is offline
Old 08-14-2017 | 10:06 AM
  #5353
Yes, basically there are 3 carbs. The plastic one (most offroad), the 3 needle and the 4 needle. I think the basic design has never changed than only the placing of the main needle and the shape of the slide needle.
Roelof is online now
Old 08-14-2017 | 10:28 AM
  #5354
BigC2007's Avatar
I see, thanks Roelof.
BigC2007 is offline
Old 08-14-2017 | 01:00 PM
  #5355
Many prefer the high and low speed needle carbs since they are easier to tune. I've had good luck on the ones that have the mid range center adjuster. It makes for fine tunning that's noticeable on bottom to mid, mostly accelerating, in my experience
