Tamiya mini cooper
The pinion access hole in the bottom of the chassis is a huge mistake by Tamiya. Including tape to cover the hole is a Band-Aid that just doesn't work. I designed a reusable plug. I printed mine on my home printer and I'll try it out this week. I have uploaded my design on Shapeways for sale.
https://www.shapeways.com/product/SE...t-chassis-plug
20170807_212150 by JatoTheRipper, on Flickr
So I think I found out why my M05v2R was pulling left when accelerating. I checked the corner weights using 4 small scales and found that the front right and rear left wheels were carrying a lot more weight than the opposing ones. I checked the preload of the shocks, and the corners carrying the most weight were set quite a bit shorter than the others, yet those wheels touched the ground first when testing droop.
I suspected the chassis was twisted, so I loosened all the screws connecting the front half to the rear half of the chassis, gave it a wiggle, then tightened it back up. The corner weights balance pretty close to even now with roughly equal length shocks. Hopefully it runs straighter next time I take it for a spin.
Obviously it works the other way around too.. if tracks right on throttle raise rear left ride height.
Wish I could do stuff like that. For real car mods too.
I posted this a long time ago but if your car tracks left on throttle while it coasts straight, easy remedy is to raise rear right ride height by a 1/2 turn or so on the damper spring seat collar. The benefit of running the hopup aluminum housing dampers vs the spring perch dampers to get that refined sus tuning.
I had the same problem. Not sure if it'd help, but I backed off a bunch of screws, twisted the chassis around a bit and tightened it all back up. Seemed to help.
I had already attempted to compensate with the collar adjustment, with 5 or more full turns and it still wasn't enough. The car was tweaked too much for fine adjustments like that to help. Fingers crossed the weather will hold out for some testing this weekend to see if it's now fixed.
If you ever want to try your hand at 3D CAD design download AutoCAD Fusion 360. It is free for hobbyists and there are tons and tons of good tutorials online including excellent YouTube videos.
I really don't think this is overengineering though. I personally believe Tamiya should have included a plastic or rubber plug, similar to this one, in the kit. The tape is a Band-Aid and if you listen to the manual and only put tape on the bottom of the chassis it doesn't last more than a run or two.
The short spring set that is usually recommended for the M-05 is pretty soft. I think you may have one of the hard on-road sets meant for touring cars.
20170807_212150 by JatoTheRipper, on FlickrThe plug design I like a lot though, should be great running in bashing surfaces. Does it pertudes out of the chassis bottom?
Is stuff entering the gear box a serious issue? I've been running my car on the track without covering the hole for 4 weekends and so far didn't notice things entering the gear box.
Yes, the plug protrudes about 1mm off of the chassis. At this point I can't think of any way to plug the hole and still have it easily removable for access to the pinion screw. But you can easily sand that down to make it as thin as your liking. Obviously you will lose strength so discretion is advised.
Got my super shorty lipo today. It's so adorably tiny! Sticks out just enough on either side of the M07 "spine."
Also got a relatively giant (full size) servo for my buggy that I'm pretty sure weighs more than the battery.
Are you running foam blocks on either side to center the battery?
295Likes
