Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 08-01-2017 | 10:01 PM
  #7066
Originally Posted by Sal Amato
Was looking over setup sheets and noticed guys are removing gears from diff, running 2 instead of 4 gears. Anyone know why?
More diff fluid, less friction, less heat, And hold up well.
james101291 is offline
Old 08-01-2017 | 11:26 PM
  #7067
jasburrito's Avatar
Adjusted timing to draw 6 amps. Geared 28/72. Was getting temps around 160 after 8 min or so. Only place I could figure out for a fan. Hope it lowers temps some. I only have 1 battery. Still it's only 1 screw to remove. But whatever.
jasburrito is offline
Old 08-02-2017 | 04:18 AM
  #7068
lexusbest's Avatar
Should i be running thicker diff fluid with 2 gears than with 4 gears?
lexusbest is offline
Old 08-02-2017 | 08:59 AM
  #7069
Default B6
Anyone have a metal idler gear for the laydown?
klx1695 is offline
Old 08-02-2017 | 09:37 AM
  #7070
Sal Amato's Avatar
Does anyone know if there is a separate part # for the plastic pieces that hold the rear sway bar onto the bulkhead? Got dead rearended and the pieces are cracked .. I can't find a part # would suck to have to buy a whole sway bar kit just for these pieces
Sal Amato is offline
Old 08-02-2017 | 09:45 AM
  #7071
shoe's Avatar
What's the senses on the B6 Club Racer. Are the electronics good enough for a novice, outdoor hard pack track ?
shoe is offline
Old 08-02-2017 | 09:47 AM
  #7072
EbbTide's Avatar
Originally Posted by shoe
What's the senses on the B6 Club Racer. Are the electronics good enough for a novice ?
The only thing I'd really want to change soon after is the servo. But for a novice I am sure it'd be great to start with.
EbbTide is offline
Old 08-02-2017 | 09:52 AM
  #7073
Would like to get a bit more snap in my B6D for a dirt track (HOT ROD HOBBIES raceway). Thinking of trying out the MIP puck system. Would this help? Would like to hear from racing puck system owners.
And is this the current puck system(dont want to buy the old model)?
http://https://www.amainhobbies.com/mip-pucks-associated-b5-b6-17.5-drive-system-mip16080/p520428
Phillip F is offline
Old 08-02-2017 | 09:56 AM
  #7074
Matt Trimmings's Avatar
Adds some snap but also takes away rear bite.
Matt Trimmings is offline
Old 08-02-2017 | 10:08 AM
  #7075
jasburrito's Avatar
I noticed mines not as snappy as many. Is 100c battery gonna give me that much more snap than a 65? I also wonder if there not in blinky. (Geared lower with added timing)
Old 08-02-2017 | 10:12 AM
  #7076
EbbTide's Avatar
100c or more will help imo. I try to run no lower than 100c continuous discharge in my 17.5 buggies. I notice a bit of a drop in punch if I switch to lower discharge packs.
EbbTide is offline
Old 08-02-2017 | 10:42 AM
  #7077
So you think its better for high traction surfaces ..like carpet?
Old 08-02-2017 | 10:50 AM
  #7078
I don't like them. But that's my opinion.
Old 08-02-2017 | 11:17 AM
  #7079
I wouldn't run pucks in a lay down... it doesn't have enough weight over the rear to make use of the quicker acceleration, plus you'd be removing even more. Now in my standup? Fuggetaboutit. Pucks all the way.
Make sure your drivetrain is as free as possible. My first B6 came alive after about two months. Built a new one (the one with the pucks) and it felt like a dog. Realized that all the crap grease in the bearings of my first one had pretty much been used up, which really freed things up. So I took the seals off the new ones, soaked them in citrus degreaser, blew out the crap with a compressor, and applied Schelle's high grade thin oil. Now the second car is a beast, too.
Jason B is offline
Old 08-02-2017 | 12:07 PM
  #7080
+1 for cleaning grease out the stock bearings: It's the best bang for the buck in stock racing.
Krio is offline
