Team Associated B6 & B6D thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 08-06-2017 | 01:55 AM
  #7096
Matt Trimmings's Avatar
Originally Posted by mushroomed
I've just opened a set and discovered that they only come with four of the hat-spacers, whereas the B6 kit uses 8 of these. The ASC91494 comes with another 4 round spacers. Rather than try these, I used the stock spacers in the front shocks. I'd suggest getting two packs if you want to use the ASC91494 unless someone can confirm they work without using 8 hat spacers.
Did you read the instructions it came with? You use 1 flat washer, xring, thick bushing, xring, hat bushing. In that order for each shock.
mushroomed likes this.
Matt Trimmings is offline
Old 08-06-2017 | 01:27 PM
  #7097
lexusbest's Avatar
Default What oil to run?
What diff oil would you start with? The track is high traction and very bumpy. Everyone is running a schumacher kc with 10k to 12k oil. should i be running similar oil in my B6? 2 or 4 spider gears?
Attached Thumbnails Team Associated B6 & B6D thread-carbifotobuena410933778_392393147601429_6781506597919891833_n.jpg
lexusbest is offline
Old 08-06-2017 | 10:39 PM
  #7098
JsK's Avatar
JsK
R/C Tech Elite Member
4000/4gears. Changing to 5000 with 2 gears gives more rotation and free the
back up under power. Schumacher diffs react quite different to fluid weight
than an AE diff so its not really transferable.
JsK is offline
Old 08-07-2017 | 12:48 AM
  #7099
lexusbest's Avatar
Thanks!!
Old 08-07-2017 | 08:12 AM
  #7100
Is there any reason to believe Associated will come out with a B6.1 before the end of this year?
Fearo is offline
Old 08-07-2017 | 09:47 AM
  #7101
I have tried stock 4K then 2 gears (too much rotation for me and less stable) then was advise to thicken the diff. Now 7k and will try 10k.
Seems more stable and consistent but we run mod on very bumpy astro with a low ride height.
I'm guessing the higher the oil the less diff out so the car is more stable at speed on bumpy section
mojo tom is offline
Old 08-07-2017 | 09:54 AM
  #7102
RCBuddha's Avatar
Vegas odd makers have it at 5:8 j/k!
I thought they were going to release a b5.1m but they ended up doing a b6/b6d. So who knows what they will do!
RCBuddha is offline
Old 08-07-2017 | 10:01 AM
  #7103
Wildcat1971's Avatar
Doubtful. But you never know.
Wildcat1971 is offline
Old 08-07-2017 | 10:40 AM
  #7104
Braxamus's Avatar
Got mine all built and have not ran it yet but not real impressed with the battery hold down, I have tried 2 different batteries and adjusted the studs like they say and neither leave enough on top to engage the nylon in the lock nuts and it seems the stud does not screw into the chassis as much as I feel safe with, and I like the quick release no tools required to take battery in and out. Does anyone make a better system or have another idea on how to improve this? It really is the only area I seen in the build that to me at least is questionable and should have been done differently.
Braxamus is offline
Old 08-07-2017 | 11:01 AM
  #7105
EbbTide's Avatar
What about this? I believe Exotek makes one too.
B6 / B6D Carbon Battery Strap
EbbTide is offline
Old 08-07-2017 | 11:07 AM
  #7106
I use these.
B6 / B6D Titanium Battery Posts and Aluminum Nuts Accessorie AV1064
Old 08-07-2017 | 11:32 AM
  #7107
I've tried a ball diff on a bumpy high grip Astro track...
It felt a little more forgiving and consistent.
Bandit10 is offline
Old 08-07-2017 | 11:47 AM
  #7108
everytime i turn, the front inside wheel wobble like crazy. Is this normal? When both wheels are centered there isn't have much slop.
james101291 is offline
Old 08-07-2017 | 12:35 PM
  #7109
aeRayls's Avatar
It's not an issue. The nuts that come with the team kit don't have nylon in them. I've never even had one loosen at all and I don't crank them down, just snug.
Matt Trimmings and TC5Driven like this.
aeRayls is offline
Old 08-08-2017 | 12:12 AM
  #7110
lexusbest's Avatar
Thanks to everyone. Think ill start with 5k 2 gear and then try 7k 2gear as i see that the most common is 5k 2 gear. We have an small carpet indoor track where 10k is good for schumachers but seems too slow for my b6. I dont want to be rebuilding diffs everytime
