Tekno MT410
#1006
On my MT I just clipped/drilled the stock posts & put in set screws. It's been working so far. I have the Proline posts on my ET, they are nice, as they eliminate the wobble the stock post have.
#1007
So are the mt410 body mounts the same as the sct410? Wondering if these will work.
TowerHobbies.com | Pro-Line Extended Front/Rear Body Mounts SCT410
Or if I have to get these and modify the mt mounts by drilling into them.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCSDM&P=M
#1008
https://tboneracing.net/collections/...er-tekno-mt410
#1010
So you cut off the little nub and then drilled into the square post and screwed in the proline screws and used the caps? I did that on my ET also but I looked at my friends SCT410 posts since they are the same as the MT (because I don't have my MT kit yet... hopefully it will be here today) and the post is smaller so I wasn't sure if it had enough material to drill into and put the screw in. But if that's what you did I will probably try that.
#1011
#1012
Exactly what parts are needed to convert the mt410 into An et48? I debated between the 2 but decided on the mt cause I already had an et48. But a track near by may be open for racing next summer and I'll probably want et48 when that happens. Would I just need the et chasis and the 2 et center drive shafts? Besides that everything else is straight off the et48 right?
#1013
EDIT: I stand corrected. Looks like the arms are the same. And of course steering assembly and such.
#1014
#1016
Damn I forgot about the towers. U have the mt410 and the et48 and you bash both right? Which do you like better for bashing? I just got the mt kit today and I started putting it together but I'm still wondering if I should have got the truggy. I do that with everything. I always second guess myself. I know the mt is Gna be a blast but just wondering which you prefer. I think I'm just Gna sell my eb48.3 and get the truggy that way I'll have the mt and et.
#1017
I'm painting up a Baja Bug body (I have several different bodies) and would have had to cut the engine detail portion of the body out using the stock rear bumper/support. The T-Bone bumpers are much flatter across bottom, I'm fairly confident this will fit with the full, intact body. Anybody with pictures of their MT with the new rear bumper?
Jay
#1018
#1019
I have the T-Bone tubular style front bumper on mine already, after checking out the new rear bumper, I HAD to have it, so it's on order. Very cool, and realistic appearing.
Jay
Jay
#1020
Referring to this rear bumper with wheels?
Jay
396Likes
