Tekno MT410
#976
Not much help here but I have these installed in my shocks but still building mine. I figured they were a cheap upgrade and wouldn't require me to re-build the shocks should I want to upgrade later. I upgraded to the exact style that comes with the kit.
#977
Yes, my PAD is installed and you want to make sure it's running 7.4V
#978
So I'm getting shock upgrades
Tkr6017t front Ti nitride shafts
tkr6061t x-long rear Ti nitride shafts
Tkr6146 delrin cartridges
I have 2 questions. Should I use the cartridges with the long bottom shaft guide or tkr6146B which has the shorter bottom piece for more shock travel (but it is less shaft support)?
Also what delrin shock piston size would be best? The option part specified in the manual Amain says is discontinued which looked to be 8x1.3. Anybody have a suggestion? 10x1.1 maybe? Or is that Gna be too much pack?
I also got the Delrin cartridge set, and pistons, alloy spring adjusters and caps. Compared with the quality of the rest of the kit, I felt Tekno really did their model a disservice with the included shock parts. Not quite ready for prime time IMHO.
Jay
#979
As far as what I would consider a very good shock upgrade, the metal cartridge caps are first on my list. I had a plastic one break very early on, which resulted in a lot of damage to that particular shock. Caused a bent shaft, broke the thin inset lip on the bottom of the shock body, and tweaked the piston.
Jay
Jay
#980
What are you thoughts on speed with this servo (HSB-9380TH)? It's a fantastic servo but seems a tiny bit on the slow side in comparison to some newer models coming out now.
Anyone have experiences with Protek 170SBL? Specs look outstanding - not sure on reliability though since I'm seeing both sides of the spectrum being reported.
#981
#983
Jay
Jay
#985
Those are discontinued. The option part no. Specified in the manual is also discontinued. Not sure which ones to get. The newer ones they have out all seem to be lower number of holes that are a little bigger but I don't know which is to go with. Was thinking the 3x2.1 (10.4mm squared) or
10x1.1 maybe. Idk
10x1.1 maybe. Idk
#986
10x1.1 maybe. Idk
10x1.1 maybe. Idk
#987
Anybody have a pic of their mt410 with the backflip tires and body on it? Pretty sure I'm going with those but want to see them on the truck. I really want the badlands mx38's cause the t tread pattern looks badass. But I didn't want a super wide tire.
Also does anyone run the Silverado body? Debating between the Silverado and the 2017 raptor
Oh and I decided on the tekin combo. The 2000kv motor is the truggy sized motor correct? That's what would be best int this truck?
#988
Finally have my truck running around my backyard. I got about ten minutes into some light jumping off an 18 inch jump tonight and the 4PLS started beeping at me. Ever since, I don't have brakes or reverse. I tried to recalibrate my ESC and it won't pass the third step, where you give it full brakes. No idea what could have happened. It's not wet out, there's no wires loose etc.
It has the Tekin gen3 1350kV truggy combo and the Futaba 4PLS.
Update: my thumb was resting on DT4 and I turned the ATL down to 0. Works great now that it's back up to 100
. Definitely a problem though that the DT4 switch is right there and so easy to move, that's a really, really comfortable place to hold my thumb. I mean, it's the part of the pistol grip where your thumb goes.
Hopefully I can deactivate that switch.
Update 2: You can definitely deactivate the DT3 and DT4 switches in the menu under SW/DIAL
. Definitely a problem though that the DT4 switch is right there and so easy to move, that's a really, really comfortable place to hold my thumb. I mean, it's the part of the pistol grip where your thumb goes.Hopefully I can deactivate that switch.
#989
Tekin - T8 GEN2 1/8 Brushless Motors
#990
396Likes
Sorry, I must not be following - you don't remember if you installed the Hitec PAD (that comes with the servo) to your receiver in the MT410?
