Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 07-17-2017 | 05:37 AM
  #6916
lexusbest's Avatar
looking to this chart Team Associated B6 & B6D - Arm Mount Pill Chart , what does pivot position mean?
lexusbest is offline
Old 07-17-2017 | 08:51 AM
  #6917
Rear hub height talk to me.
When going from 0 to +3 what is the difference to the roll centre? Is it higher or lower.
Cheers
Mi4cxl is offline
Old 07-17-2017 | 09:41 AM
  #6918
Rebuilt shocks with new xrings this weekend. Can the xrings be "refreshed" or rejuvenated at all so i'm not blowing 10 bucks every rebuild? The rubber seems more pliable and supple than the old red o-rings so do they last longer? Anything to bring them back after they have swollen up?
daedalus is offline
Old 07-17-2017 | 10:12 AM
  #6919
davidfast's Avatar
No, but how often are you rebuilding?
davidfast is offline
Old 07-17-2017 | 10:20 AM
  #6920
I might be converting my B6D to offroad eventually.
Latemodels are dying out here Unfortunatley.
I haven't raced at that track in 2 months and they have stopped showing up.
I just hope the body and wing are strong. I had a launch model original B44 4 wheeler and the wings were garbage. One weekend I trashed mine.
bmag5000 is offline
Old 07-17-2017 | 11:05 AM
  #6921
Once a month... about every 4 runs.
daedalus is offline
Old 07-17-2017 | 11:27 AM
  #6922
davidfast's Avatar
Seems a bit quick , are you using green slime? How abrasive of an environment are you in as well?
Old 07-17-2017 | 11:40 AM
  #6923
Yea a bunch of green slime and I just run on hard packed clay. How often should i be rebuilding?
daedalus is offline
Old 07-17-2017 | 12:09 PM
  #6924
Wildcat1971's Avatar
Tech Prophet
My current track is eating orings. Need to be replaced every couple weeks or so. Anyone find orings in bulk? Mcmaster carr?
Wildcat1971 is offline
Old 07-17-2017 | 01:32 PM
  #6925
mellow's Avatar
I never had good luck with the ones from mcmaster during the B4 era. They always had a lot of stiction. There's gotta be somewhere that has these in bulk though.
mellow is offline
Old 07-17-2017 | 01:55 PM
  #6926
Tech Prophet
The traxxas xrings use to be ok in the original B5 V1 shocks. Not sure if anyone uses them anymore.
Old 07-17-2017 | 06:02 PM
  #6927
Default Pistons
How many people using machine pistons.the out side is different size from the stock pistons.why.and do I need to up on oil.thanks
FLYINGBRIAN is offline
Old 07-17-2017 | 07:33 PM
  #6928
Johnn27's Avatar
Questions?? Rear Tire insert for Astroturf
What tire insert are racers running in their rear tires on astroturf?
Johnn27 is offline
Old 07-17-2017 | 08:50 PM
  #6929
Schumacher Medium blue foam
mojo tom is offline
Old 07-18-2017 | 12:30 AM
  #6930
Matt Trimmings's Avatar
I would say most are using machined pistons, its not that they are larger...but they are machined to a better tolerance than the molded pistons could ever be. You shouldn't need to change oil thickness.
I use JC Dirt Tech in the rear....like anything its a tuning option.
Matt Trimmings is offline
