Team Associated B6 & B6D thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 06-19-2017 | 02:34 PM
  #6766
Wildcat1971's Avatar
Originally Posted by monkeyracing
I've reached the point in my B6d build where I'm installing the slipper. I've got a choice. I could install the stock one, or I could transfer the VTS slipper from my B4.
The only issue is the VTS is super glazed. I've cleaned up the pads easily enough, but the plates have an incredibly polished mirrror finish on them. Can I just go over this with some 600 grit to fix it up?
use the one that came with the b6
Wildcat1971 is offline
Old 06-19-2017 | 03:10 PM
  #6767
monkeyracing's Avatar
R/C Tech Elite Member
Alrighty. Will do, thanks.
monkeyracing is offline
Old 06-19-2017 | 03:40 PM
  #6768
rc pete's Avatar
Originally Posted by dogbone418
I have screws, i'm asking basically how to get the stripped one out. Dremel is easy when you have access to the screw. thinking i may end up stripping the thread in the top plate and front bulk head.
Look for a screw extractor kit at your local hardware store. You'll want the micro set that fits RC sized screws. Good luck!
rc pete is offline
Old 06-19-2017 | 05:14 PM
  #6769
mick33b4's Avatar
Originally Posted by lexusbest
what is the difference between using thin oil vs thicker grase? i read some people using shock oil for that purpose
In my opinion, grease lasts longer. It's a little thicker, so probably not as fast as the shock oil. When I open my gearbox with grease, there always seems to be some left on the gears. Usually find it dry with shock oil. Some guys use Mobil 1 grease, some use the exotic Dupont grades (Krytox). I like that the Super Lube is similar in base to diff lube, and as mentioned, the sealing benefit.
mick33b4 is offline
Old 06-20-2017 | 03:33 AM
  #6770
lexusbest's Avatar
Thanks! Will try
lexusbest is offline
Old 06-20-2017 | 01:55 PM
  #6771
TC5Driven's Avatar
Ok, here's one. anybody strip one of the 3x12 screws that go down into the top plate? Bag 2-4 Step 5 in B6 manual. Picked up a used one and I noticed the stripped screw. Not sure the dremel tip is going to get down in there.
I ran into the same problem a few months ago. I just drilled it out by starting with a small drill bit and going up on drill size until the screw head pops off. If all else fails just drill the heck out of it and replace the front ball stud mount.
TC5Driven is offline
Old 06-21-2017 | 06:54 AM
  #6772
Try JB Welding an Allen key in there
SlashBash10 is offline
Old 06-21-2017 | 10:40 AM
  #6773
Has anyone tried the four gear transmission yet? I run on an outdoor track that is pretty bumpy. Traction is getting harder to come by as it gets hotter and the groove seems to be less prevalent. The 4 gear in my SC5M is much much better than the 3 gear at my track. Matt
Crtrck48 is offline
Old 06-21-2017 | 11:08 AM
  #6774
Team Associated B6D - Ray Munday - Outdoor Setup & Tips - 16.08.2016
Im sure there is updated information out there somewhere but that should get you started in the right direction.
Edit. The update was in the wiki. go figure.
http://site.petitrc.com/setup/associ...oorSetupGuide/
Rebuke is offline
Old 06-21-2017 | 07:18 PM
  #6775
Perfect! Thank you Sir!
Team Associated B6D - Ray Munday - Outdoor Setup Guide
Crtrck48 is offline
Old 06-21-2017 | 09:35 PM
  #6776
Muggydude's Avatar
What's the verdict on lightweight bodies? Worth it? How do. They held up. Looking at predator, s2, and f2 bodies
Muggydude is offline
Old 06-21-2017 | 11:05 PM
  #6777
My S2 body is great, just made the buggy feel more stable on high grip astro. Around a 22g weight saving over the standard shell.
Mi4cxl is offline
Old 06-21-2017 | 11:27 PM
  #6778
I've got no more race damage on my lw body than standard in 10 or 12 race days. I have however put a tear in it from release'n the Velcro so that's something to watch out for.
Rebuke is offline
Old 06-22-2017 | 03:53 AM
  #6779
Muggydude's Avatar
Vrc pistons - Medium sized, med-high traction clay track. Which pistons should I get? Front and rear 2x1.5 a good start?
Old 06-22-2017 | 04:05 AM
  #6780
Johnn27's Avatar
Thumbs up
1.6 F / 1.7 R is what I was running
Johnn27 is offline
