Tekin Hotwire 3.0 Bluetooth Thread >
Like Tree21Likes
Old 01-03-2020 | 06:56 PM
  #181
Centerline Racing's Avatar
I know this is not the 2.0 thread, but I had to purchase one due to no stock of the 3.0.
What's up with the Hotwire pc software? I can't install on a Windows 10 machine. I have .Net 4.8 and it keeps telling me to install .Net 2.07??
Please help.
Centerline Racing is offline
Old 01-03-2020 | 07:35 PM
  #182
trilerian's Avatar
Please help.
.net 2 is part of .net 3 and you should be able to enable it in your Windows Features. Control panel-Programs-Turn Windows Features on or off.
trilerian is offline
Old 01-04-2020 | 08:15 AM
  #183
That worked. Thanks for the tip.
Old 09-26-2020 | 09:40 AM
  #184
joelm's Avatar
Not working I have the 3.0 Bluetooth and it will not power up has anyone else had issues? It worked last weekend and this morning nothing
joelm is offline
Old 01-19-2021 | 04:37 PM
  #185
rgrg2's Avatar
Default Update
Does the HotWire 3.0 have to be hooked up to a PC with a wire, or can I use the PC Bluetooth to connect to the Bluetooth 3.0 and do a software update to the Hotwire?
rgrg2 is offline
Old 01-19-2021 | 04:57 PM
  #186
Tekin Prez's Avatar
Team Tekin
You can only do software updates on PC or device with windows and a USB cable. We do not allow software updates for esc with Bluetooth connection with mobile devices, but interesting idea for PC with bluetooth. Currently there is no where in the windows program to connect with Bluetooth.
rgrg2 and Mahjik like this.
Tekin Prez is offline
Old 01-19-2021 | 06:01 PM
  #187
rgrg2's Avatar
Default Hotwire
Thank you!
rgrg2 is offline
Old 01-30-2021 | 08:47 PM
  #188
My HW 3.0 will not bind to my Pixel 5. Ive tried everything. First off the directions say to power on JUST the ESC, but when I do, no lights come on on the HW. I have to have my transmitter turned on to be able to get the blue flashing light. Aside from that I hooked up the ESC via USB to my PC and downloaded the software. Everything worked fine on PC via USB. First, I updated the FW, then I changed my setups to 3s and 7.4v BEC, then I made sure "Fan always on" was selected. After saving settings I re-calibrated the ESC and attempted to pair BT once again and it still doesnt work.
rc10mike is offline
Old 02-01-2021 | 07:16 AM
  #189
One of the issues I ran into with one of my configs is that BT won't connect while my receiver is connected to the ESC:
Might try disconnecting the receiver and see if BT binds and connects.
Mahjik is offline
Old 02-01-2021 | 03:24 PM
  #190
This worked! Thanks a ton!
Mahjik likes this.
rc10mike is offline
Old 04-11-2021 | 06:16 AM
  #191
I purchased a hotwire BT. I have both a RSX Pro and a RS Pro BE. I can Bind the Hot wire (it says bind successful) but each time with either speed control it can't find. My trim is in the middle and locations are turned on in my Samsung Galaxy 9 .......it just says "no hotwire bluetooth found. I can use it with the cable to PC but I already had a hotwire for that . I bought this one for the bluetooth feature.
tkcamp is offline
Old 04-14-2021 | 04:37 PM
  #192
lowspark's Avatar
Make sure the bluetooth is turned on in your phone or tablet. I made this mistake once trying to bind and the bt was switched off on my ipad.
lowspark is offline
Old 04-19-2021 | 07:23 AM
  #193
Please help.
Also note that due to some unknown .net framework procession of updates along the way windows 10 may have lost its certificate for HTTP activation and selecting 3.5 may not install properly however under that windows features on NET framework 3.5 the selection can be branched out and select only NON-HTTP activation.
Juglenaut is offline
Old 04-30-2021 | 11:43 AM
  #194
Default 280 vs. 276 Firmware
I updated my RSX Pro to 280 and of course I lost the ability to use the Hotwire via Bluetooth. I didn't catch the disclaimer.
1. When do you think the app will be updated to work with 280?
2. Am I OK to reload 276? I am guessing it is OK to go back a software level since it still shows on the site.
crashr30 is offline
