Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 03-01-2017 | 07:09 AM
  #28726
NomadRacer's Avatar
Originally Posted by monkeyracing
Yup. TQ is awesome. As for pinion, try to get either the fluorine coated Tamiya one, or one of the other hardened models that are available. )Kawada, Yeah Racing, etc) The stock pinions are garbage and will chew up the plastic gears in short oter.
Is this the Tamiya fluorine coated pinion to use?
Tamiya 53509 0.6 Alum Pinion Gear - Hard Fluorine Coated 20T
NomadRacer is offline
Old 03-01-2017 | 10:05 AM
  #28727
ErikJan's Avatar
You can also get a steel pinion, like this, lasts forever. I use this pinion since 2007, first in a m03, now in the m05. And I race almost every week.
Carson Pinion Gear Module 0,6 steel, 20T
ErikJan is offline
Old 03-01-2017 | 01:20 PM
  #28728
gigaplex's Avatar
Yes
NomadRacer likes this.
gigaplex is offline
Old 03-01-2017 | 03:46 PM
  #28729
NomadRacer's Avatar
Thank you kindly for the pinion help.
Old 03-01-2017 | 04:56 PM
  #28730
Have a 3 racing gear diff and put in 2.5mill oil and am getting a lot of wheel spin on black carpet any suggestions running orca motor
RevolutionM is offline
Old 03-01-2017 | 05:32 PM
  #28731
banana rt's Avatar
anyone here using m05 v2 arms and feel inconsistent droop ?
banana rt is offline
Old 03-01-2017 | 08:45 PM
  #28732
I run at the same track you are and have 500000 in my diff. It seems to work really well.
Yellow front springs with 40 oil and yellow back springs with 30 seems to be the ticket.
Jim would know best.
elecsual is offline
Old 03-01-2017 | 08:53 PM
  #28733
What would you guys say the minimum servo strength and speed for a 21.5/2200kv mini M03 would be? Would 43oz-in and 0.3s due the job? Or do I really need to get up to 100oz-in?
My LHS has the Futaba S3151 and S3305. Just wondering if I need the extra strength.
PS, I'm stuck with futaba because of the servo saver I'm using.
elecsual is offline
Old 03-01-2017 | 09:10 PM
  #28734
monkeyracing's Avatar
Wheelspin is part of the game, even on the awesome new carpet. You could try dealing down the aggressiveness/throttle curve on your ESC?
I know nothing.
Torque isn't as important as speed. I'd go with 0.10/s - 0.15/s minimum.
Wednesday practice night report:
- M04RR - does wheelies quite well, otherwise sketchy
- Xevo - still blindingly awesomely grippy
- m05 - fixed the hard pull to the left with spring tweaking. Thanks!
monkeyracing is offline
Old 03-02-2017 | 11:50 AM
  #28735
marcos graveyar's Avatar
Not me, but I have added metal plates made from old jigsaw blades to the chassis-droop screw contact points. I felt that the droop screw acting on the plastic chassis could cause wear and therefore affect the handling.
It's superglued in place, the cable tie is just a boots and braces thing.
The same thing is done on the front, less the cable tie obviously.
marcos graveyar is offline
Old 03-02-2017 | 04:11 PM
  #28736
Schs2013's Avatar
so getting to rebuild the mini wheelbase to 225mm(M) from 210mm(S) and wow just challenging to find one of these bodies by Tamiya HPI..... list goes on.
Schs2013 is offline
Old 03-02-2017 | 04:41 PM
  #28737
Yea, I hear you on how challenging it is to find Tamiya bodies. I ended up grabbing an ABC Hobby body for my M05 and have it in reserve. I'm glad I can stick to the short wheelbase with it. Actually I'm quite impressed with it's level of detail.
I've had to throw the towel in on HPI parts in general (bodies & wheels specifically) - I want to get my new chassis up and running (just tires and body left to do).
RCReggie is offline
Old 03-02-2017 | 10:26 PM
  #28738
banana rt's Avatar
im running m05 arms on my v2 chassis and feel way more consistent, i set ny droop from shocks length.
Old 03-03-2017 | 10:48 AM
  #28739
This looks like a better solution than the recycled pieces of razor blade I was using. Very hard steel, but it was thin enough to indent after a time. That said, I gave up on the built in droop screws and went back to building shocks to length. I lose easy adjustability, but I only ever race at one track anyhow.
Old 03-03-2017 | 11:02 AM
  #28740
Ooh! New diff from RCMart's house brand, Yeah Racing. Looks a lot like the others that are out there already, but comes with a chunk to turn it into a spool, should the need arise. Neat.
For M05 - Yeahracing - (#TAMC-023) 38T Gear Differential Set For Tamiya M05 M06
RCReggie likes this.
