Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-30-2017 | 04:50 PM
  #1171
eR1c's Avatar
I painted up a new body for my TT02,
I don't have the correct wheels on it, ...i put them on quickly to snap a few photos. They have the incorrect offset in the rear. Also I have to trim the body posts so they are not sticking up so high. ...so kind of still a work in progress.
Attached Thumbnails Tamiya TT02 Thread-01.jpg   Tamiya TT02 Thread-02.jpg   Tamiya TT02 Thread-03.jpg   Tamiya TT02 Thread-04.jpg
eR1c is offline
Old 01-30-2017 | 08:08 PM
  #1172
Raman's Avatar
Nice paint job.. Looking good
Raman is offline
Old 01-31-2017 | 09:50 AM
  #1173
eR1c's Avatar
thanks!
its simple, ..but it works for me.
eR1c is offline
Old 01-31-2017 | 07:49 PM
  #1174
Raman's Avatar
Not so simple.. you did all the panel lines in black.. that's a lot of work!
Raman is offline
Old 02-01-2017 | 12:05 AM
  #1175
tobyzhang's Avatar
Anyone has experience running the TT02 type s for TCS spec novice? My girl friend is doing spec novice class this year with a TT02R but I'm curious if the much more precise ta05 long reversible suspension makes a noticeable difference with the crappy spec tires.
Thanks!
tobyzhang is offline
Old 02-01-2017 | 01:26 PM
  #1176
k_bojar's Avatar
Thanks!
is the type S even legal for TCS novice class? i know its outlawed for the pro-spec class
k_bojar is offline
Old 02-01-2017 | 05:04 PM
  #1177
tobyzhang's Avatar
TT02s is legal per the 2017 tcs rule pdf
Old 02-09-2017 | 09:50 PM
  #1178
Just got the tt02 new fibre reinforce tub and white part. Will start working tonight
tommy1030 is offline
Old 02-11-2017 | 10:26 AM
  #1179
trooper5707's Avatar
Hey all, love all the data in this forum, really great stuff! I live in Nashville and started putting together a TT-02R to try and run USGT at Thunder Racing. I have a TrackStar 21.5 Brushless, Hobbywing stock Spec ESC, and Savox servo. The battery is racer's edge 2S, 5000mAH. I stopped in one weekend and the cars there are super competitive, I think starting with a TT02 may be tough! FDR is 3.7 - 3.8, so I plan to try and run a 72T spur with a 50T pinion. I know I have a lot to learn to get racing, but hope to have some fun as I learn.
trooper5707 is offline
Old 02-11-2017 | 11:27 AM
  #1180
MD's Avatar
MD
With the stock gears in the TT02 you won't be able to run a 72 spur. You may have to figure how to achieve a similar FDR using Tamiya gears. They are a different pitch. When I ran a TT01E we ran 55/25 with the solver can motors.
MD is offline
Old 02-11-2017 | 12:07 PM
  #1181
You can get just about any FDR you desire in the TT-02
Please see below.
http://www.thercracer.com/2014/04/ta...ta-blinky.html
Metalsoft is offline
Old 02-11-2017 | 02:16 PM
  #1182
Thanks, I am running the R model, which includes the adjustable aluminum mount and the high speed gear set. It includes a standard spur holder, so I can swap over to any standard spur gear with matching pitch pinion, and should not be limited to the Tamiya pitch gears (unless I have misread)
Old 02-11-2017 | 02:40 PM
  #1183
The R comes with an aluminium mount but not an adjustable one. You need one by 3Racing or Yeah racing. They are cheap
Qatmix is offline
Old 02-11-2017 | 03:30 PM
  #1184
Got ya, thanks!
Old 02-11-2017 | 06:47 PM
  #1185
Here is the car, I should prob shorten the motor wires
