Like Tree43Likes
Destiny VD12
Old 12-12-2016 | 04:27 AM
  #61
Originally Posted by 303slowdown
Im also hoping someone can shed some light on side link lengths . What does having the really long side links do ? Ive only seen one other car with the really long links ( SM Rev8 ). I have both length links but wich one would be better on the black crc carpet.
I run in Cleveland OH at NORCAR. We have the new black CRC racing carpet. My plan was to set the car up using the long side links (just because for the past few years I have run a CRC car), and once I get it set-up, swap the long out for the short and see what the difference is....
Micro_Racer is offline
Old 12-12-2016 | 08:12 AM
  #62
Mart42's Avatar
Now all we need is someone to make an optional servo mount to fit some other sevos . I have 9650 and spektrum 5020 and cant get either to be centered , holes in plate are in wrong places. What servos are people running ?
I switch to Roche P12 '16 floating servo top plate... Direct fit.
Less shorter length adjustement for the center damper tough.
Mart42 is offline
Old 12-23-2016 | 06:13 PM
  #63
Having the same issue, using a Savox SC1250 and it doesn't fit either.
Disappointing to have a brand new car and now I have to either mod the plate, buy a different servo or buy a Roche plate for it.
Destiny needs to fix this issue.
TeamBear is offline
Old 12-23-2016 | 06:53 PM
  #64
I started making a few of these for guys who had the same problem
chad508 likes this.
Racermac73 is offline
Old 01-02-2017 | 09:52 PM
  #65
303slowdown's Avatar
Are there any websites that plan on listing parts for these cars ? Or just dont plan on breaking anything other than front end parts.
303slowdown is offline
Old 01-03-2017 | 07:38 AM
  #66
I will check with Scott, but I believe the initial shipment only included the car kits.
RBLove is offline
Old 01-15-2017 | 08:21 AM
  #67
Default Servo
We made the racing car (not a toy) so we made major servo fit to VD-12 (Sanwa, JR and KO)
CRC had made original design for Sour gear and but no one is using.
This mean servo manufacturers must make the compatible size servo and not the car design.this is the basic idea for third party.
Teru is offline
Old 01-15-2017 | 01:51 PM
  #68
Teru, do you know when parts will be available ? I would like to buy some spare side links and center pivot parts.
Old 01-15-2017 | 05:10 PM
  #69
It is available in US market already.
Teru is offline
Old 01-16-2017 | 10:36 AM
  #70
Anyone have an editable setup sheet for these?
Antimullet is offline
Old 01-23-2017 | 07:53 AM
  #71
I haven't seen one yet. For reference, here is what I have been running in 13.5 and it seems pretty good:
Kit chassis plate
Kit side springs (yellow) just touching
Kit center spring (yellow) with 500cst in shock
Center shock mount plate flipped to underside of servo mount for more inclination
15k Kyosho in 'standard' tubes
Kit ~170mm rear width
5 degree reactive with 4 or 5 degree static (both seem good)
No spacers on front lower arm mounts, 1.5mm spacer on axles
1 degree camber
30k Kyosho in front mini tubes
Kit front springs (think they are Xenon .50)
Protoform AMR, mounted middle of wheel well
Battery back
LloydLoar is offline
Old 01-25-2017 | 03:31 PM
  #72
Thanks Chris! Trying it now.
Old 01-26-2017 | 08:05 PM
  #73
Teru,
Asking servo mfg. to make a servo for our 1/12 cars is crazy. Our market is so small I don't see that happening. You may want to rethink your direction and provide a car that people can get electronics to fit. If not you may want to state in your manual what servo you designed the car around. You may want to help people out a little rather than dodging the question.
Steve
sdunnmcp is offline
Old 01-27-2017 | 04:46 AM
  #74
Peakki's Avatar
try testlogger.info
I've made it there.
Many cool features in testlogger.info
I've been running preproduction car for quite long time and have experience of 13.5T blinky with GT body and 3.5 boosted & 6.5 blinky mod with LMP body.
Inline is the way to go, faster corner speeds and better speed out of the corner!
Peakki is offline
Old 02-02-2017 | 12:48 PM
  #75
Default Destiny V12
Looking for a Destiny V12?
http://www.ebay.com/itm/282347997693...84.m1557.l2649
Copy and paste on Ebay.
Bill
billbob49 is offline
