Team Associated SC5M Thread
#2058
Pro line Raptor
Can some who has the flotek raptor show how they mounted the rear post. Seems there is a week spot if you cut the holes out in the back of the body. Thanks in advance.
#2062
For those running the laydown in the SC5M what company's laydown are you running?
#2063
Will the b6 lay down transmission work?
#2064
Has anyone experienced this? It seems like the stock axle has a wider offset than the t5m axle with 6.5mm clamping hex. Would putting a bigger clamping hex such as the 8.5mm snug it up more? Or would I be better just to remove those and put the stock axle back on?
#2065
Also another question, I replaced the front axles with the T5M clamping axle (ASC71013) so I could use the 6.5mm Clamping front hexes. I noticed after putting on my wheels (Jconcepts 3mm offset Hazards) that the wheel nut is all the way bottomed out when putting the nut on. There is a little flex as it seems like there is half a turn maybe left that it would need to be completely snug.
#2066
That's what I was thinking but wanted to make sure it wasn't something I was doing wrong or I was crazy. I like the idea of the clamping hex but I also would rather have a wider offset for more stability.
Do the hard arms make a difference or are they pretty much the same as the standard arms?
#2067
#2068
#2069
Thanks man. Do you know of any lay down trannies that'll work? I race indoor clay
