Team Associated SC5M Thread
#2026
Tylem28. You're overthinking something which many have done with no issues. Go back and reassemble the VTS and see where the issue is. I can't think of anything else which would cause this issue besides the slipper being messed up. It can be tricky to line it up correctly.
#2027
I'm pretty sure I had it all assembled correct but I could have had something wrong. I'll retry tomorrow and see if I still have the same issues or I put it together right. If it still doesn't work I'll take some pictures and load them to show and make sure I'm not missing something or doing something incorrect. Do those pictures above help in showing the differences between the two?
#2030
try a lower ride height. I am at 26/24 and really like the planted feel of the truck. may have to add a limiter or two to keep the springs seated at full droop.
#2031
#2033
#2034
I am running 3 up front, 2 in the rear. Are you using Cav's SRS setup @ 25/23 ride height? just looked at his setup sheet - 37.5wt/30wt, kit pistons.
#2036
I finally got my kit together and went out to a local clay track. I've been running a heavily modified slash. Wow what a difference! I love this thing. It handles like a dream and takes the jumps with ease and is so smooth. It lands so soft and is a lot easier to control.
I ended up getting the new XR10 Pro 160A ESC and a Fantom 8T motor. I love it so far! I bought the LCD program box to and will play with some settings. I put the 3 gear transmission in and everything else is on stock set up.
Just thought I'd share my first experiences. Wishing I would have picked one of these up sooner!
