TLR 22-4 2.0 Race Kit Thread! >
Like Tree243Likes
    Hide Wikipost
Old 06-20-2016, 06:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22-4 2.0 Race Kit Thread!
Last edit by: Kraig
Here are some good build tips and notes from b1narych0ice (thank you):
Specific build step comments/warnings, including areas I replaced stock parts -- Think of this as a FAQ that answers questions I had from other builders about each step:
A-3: You can instead use TLR Aluminum Servo Mount here.
A-5: Be sure to get the shorter screw in the correct hole.
A-6: Use a 76 or 78T spur if you are running a 13.5T-21.5T motor instead of the 84 in the kit! and...
A-6: The plastic washer between the pulley and the thrust assembly should be oriented so that the flat side goes toward the pulley, and the side with the ring goes towards the thrust assembly's metal washer. Diagram in instructions is correct, you just can't see that this washer isn't flat on both sides from the illustration.
A-7: Be sure the nut holding the Full-Time 4WD assembly is nice and tight, I have seen it get loose in the 1.0 car!
A-9: Put the gears on the jackshaft before the c-clips, so that you don't have to deal with getting the c-clips off to put the gears on
B-2: It seems to be possible to push the outdrives on so tight that they bind when spun, be sure to ensure that they spin freely as the manual notes.
B-7: You're screwing the 1.3mm screws into metal, don't crank so hard you strip the heads on the screws. While this is metal-on-metal, the manual doesn't call for loctite here.
B-8: The rear diff has fewer/bigger teeth, the front diff has more/smaller teeth.
C-3/C-4: TLR Aluminum Bellcranks and Exotek steering rack can be used here to increase durability/reduce steering slop
C-8: TLR Aluminum A/B Horn can be used to increase durability/reduce steering slop.
D-2: Don't worry about the kingpins sticking out the front even when the nut is tight, the bumper will push them in and keep them there.
D-5: Shock tower screws were the tightest plastic part on my kit, look from the side when tightening down the tower at the gap between the tower and the front bulkhead, tighten until this gap is closed.
D-6/D-7: Don't mix up the CVA pins and the hex pins, should be easy because hex pins are black and CVA pins are silver.
D-8/D-9: Use a toothpick to get threadlock in the metal block instead of applying it to the shoulder bolt, so that you don't get it between the plastic spindle and the metal block.
E-1/E-2: Don't mix up the 10mm pins for the rear hexes with the 11mm pins for the rear CVAs! They are packaged together and both silver, so it's easy to think you just have 4 pins that are the same!
G-1: No need to install the post on the right side if you are running a shorty and use velcro to attach the body to the mud guards. You can move the right post up or down a little so that it snugly fits your shorty battery.
G-2: Aluminum Servo Horn can be used here.
G-4: Adjust the length of the link and the servo horn position so that both the servo horn and the horn on the bellcranks are parallel with each other, and perpendicular with the link.
Hope this helps some of you that are putting your kits together, and thanks to Frank and the TLR crew for a solid kit!
Driveshaft Update from Frank - I've reviewed some parts today from stock. The 'issue' part is definitely the rear CVA driveshaft bone. The pin slot is not 90* to the bore for the barrel. We are working to get good parts made and here for CS use ASAP.
Some of the parts I checked were not 100% free, but definitely run-able. Keep in mind that the driveshafts should wear in fairly well, and quickly (within a few packs). If you have a 22-4 2.0 and are experiencing issues with the driveshafts, we won't have good replacements for probably a couple of weeks (no definitive timeline yet), so I would recommend running them on track for 1-2 packs, then rechecking. I think most will free up well.
I am sorry that we are having an issue. Everything was great during samples until production, but we'll make sure to get it right, and make it right for those with the bad parts.
What is the proper level for the diffs...i am used to building 8th scale diffs, i would assume its the same?
Just under level. You need some room for the output gear that is in the cap.
Frank can u explain what is the difference between the a and b horn, TLR331018?
It isn't the horn, it is the ackermann setting. B will have less off power, better mid corner steering. A will have more off power steering, less mid corner.
Print Wikipost
Old 12-02-2016, 04:55 PM
  #901
tsair's Avatar
Anyone know of another steering rod end that will fit that's a little longer than 231029?
Mine stripped today, and looking at it there's not a whole lot of threads being used, so I think a longer one would work better.
tsair is offline
Old 12-02-2016, 09:42 PM
  #902
tsair's Avatar
I'm thinking LOSA6001 might work?
https://www.amainhobbies.com/losi-44...osa6001/p15237
tsair is offline
Old 12-03-2016, 03:57 AM
  #903
Trader Rating: 39 (98%+)
No one is running this buggy on carpet??
tripple is offline
Old 12-03-2016, 11:42 AM
  #904
tsair's Avatar
Ok, for stripping steering link rod ends, this works pretty good.
I had some old school Losi HD ballcups for 3/16" ball studs, part number LOSA6025.
Then I used a 3.5x75mm TLR turnbuckle, part number TLR234038.
It is crazy beefy now, might start breaking other parts, but the rod ends ain't coming out!
Finished product:
tsair is offline
Old 12-03-2016, 03:42 PM
  #905
Lol....thanks for your info
J/k
tripple is offline
Old 12-03-2016, 07:00 PM
  #906
Can someone give me some insight on the gearing. I saw in the O.P. That recommends running a 76-78 spur with a 13.5 which is what I am running. I built the kit as is and seems to be quick but not sure if I am missing out on some power. TIA
j.gurnitz is offline
Old 12-03-2016, 10:33 PM
  #907
tsair's Avatar
What is your question? Start with stock gearing, gear higher for more top end or lower for more low end or if your motor is running too hot. That's about it.
tsair is offline
Old 12-03-2016, 11:47 PM
  #908
Trader Rating: 43 (100%+)
I run 76/26 with a 13.5 and it's pretty punchy on a medium size high bite track
Phillip F is offline
Old 12-04-2016, 06:11 AM
  #909
jgroenhof's Avatar
Loosen your rear belt for 13.5 and your all set.
jgroenhof is offline
Old 12-04-2016, 06:20 AM
  #910
Trader Rating: 515 (100%+)
I run 27-29/84 with a Fantom 13.5. I seem to like the 29 the best. 76/26 is virtually the same as 84/29. More than anything it depends on your tracks size and surface. Motors are also not all the same. You need to run the car and gear it to where you like it and it doesn't catch on fire after 5-7 minutes (however long your mains are).
QDRHRSE is offline
Old 12-04-2016, 07:28 AM
  #911
That's where I got confused because I was doing the calculations and they are basically the same mathematically speaking but I wasn't sure if there was advantage running a smaller spur and larger pinion. Motor temps are good after 5-6 minutes so I'm good on that end. Thanks for all the input!
Old 12-04-2016, 09:46 AM
  #912
tsair's Avatar
If you go smaller/smaller, it will be the same ratio, but have less rotating mass. On some cars, it moves the motor location a bit, but not really on the 22-4.
tsair is offline
Old 12-04-2016, 11:42 PM
  #913
First time racing this beast. My first 4wd 13.5T .. very happy with the car. I don't think I'm getting a 2017 XB4 or even an AE B64. This buggy is very driver friendly. Did not break front pivot. amazing buggy.
Old 12-05-2016, 04:07 AM
  #914
Default 22-4 ESC Setup
Originally Posted by Frank Root
Hey Guys,
Sorry it took so long to add info to the "1st post". The 22-4 2.0 has been the result of a lot of work by our team here at TLR, and I think you guys are really going to dig the car.
Web Page:
http://www.tlracing.com/Products/Def...rodId=TLR03007
Product Video:
https://www.youtube.com/watch?v=nYYcc11938I
Frank Root's Live Q&A (from morning of announcement):
I don't think I can actually grab a link, so, then find the TLR's Frank Root 22-4 2.0 video.
Images:
Setup Sheets:
http://www.tlracing.com/Products/Def...007#prodSetups
Hello. Looking for a setup that includes electronics programming. It's a Losi 22-4. 5.5 motor. Tekin RSX. I don't want to smoke any of my electronics. What's a good starting point?
Thanks!
Miko1976 is offline
Old 12-05-2016, 10:04 AM
  #915
Default 22-4 vs TEN-SCBE or TEN kit converted to buggy
Hi guys. I am not new to RC but am somewhat new to RC trucks. I would like to ask for a functional and/or performance comparison between the 22-4 buggy and the TEN-SCBE other than the fact that the SCBE comes RTR. I also understand that one could build the SCTE V3 and convert to a buggy.
Since I still mostly do airborne RC, I am leaning towards the TEN-SCBE but may go the 22-4 route. I'd like to have a durable quality off road vehicle that could be raced but also just for fun. We do have a local outdoor dirt track for 1/10 scale electric.
I have a DX4S to operate with.
rhodesengr is offline
