Like Tree256Likes
Tamiya TRF419
Old 11-14-2016 | 08:28 AM
  #3046
Great results for sure....
bertrandsv87 is offline
Old 11-14-2016 | 02:31 PM
  #3047
Marcika's Avatar
Thanks for the feedback.
I will place order once all items are available (spacers currently limited), hopefully soon.
Pls keep us updated with testing !
I will share my further experience as well.
Marton
Marcika is offline
Old 11-18-2016 | 08:55 AM
  #3048
Default Tamiya TRF419X Touring Car Large Diameter Short Spring Set #42306
Hi Guys
May I know if anyone has tried using the Tamiya TRF419X Touring Car Large Diameter Short Spring Set (#42306) on the TRF419X car? The spring set consists of the following:
a. 1 pair of soft springs;
b. 1 pair of medium springs (which is the stock TRF419X's springs and please correct me if I'm wrong); and
c. 1 pair of hard springs.
May I know how do you find it as compared to XRay regular and 2.5-2.8 progressive springs?
Thank you.
Kakaru is offline
Old 11-18-2016 | 10:07 AM
  #3049
I have the 419X have to rebuild shocks ever race day what O-rings are you using to keep the oil from leaking
tbamsey is offline
Old 11-18-2016 | 10:15 AM
  #3050
tbrymer's Avatar
TJ, I'm not sure if the xray orings will fit, but had the same issue with the ARC R11 until I put the xray orings in them.
tbrymer is offline
Old 11-18-2016 | 12:30 PM
  #3051
Marcika's Avatar
Use blue one but shim it properly 0.2-0.3mm shims needed ( 4mm wide shim!dont use 3mm shims since it will scratch the rod) same size of shims used for center pulley!
Springs - xray or smj the top springs today imo. I will test them only....
Marcika is offline
Old 11-18-2016 | 12:51 PM
  #3052
Mach10_shooter's Avatar
This is what you want... These work much better then the blue o-rings.
http://www.tqrcracing.com/shop/produ...w.asp?p_id=595
Mach10_shooter is offline
Old 11-19-2016 | 01:41 AM
  #3053
Yep, I use the clear ones for my club car. Very low maintenance.
Qatmix is online now
Old 11-19-2016 | 08:09 PM
  #3054
Raman's Avatar
The clear ones are the best from Tamiya. The Re-re Sand Scorcher shocks leaks like a sieve. When I installed the white ones in place of kit red, they became real dampers again.
Raman is offline
Old 11-20-2016 | 09:49 PM
  #3055
Default Exotek Racing C-Hubs
Have you guys had any problems with binding?
What inserts do you guys use? Stock ones or the ones from exotek?
TeamThibault is offline
Old 11-20-2016 | 10:12 PM
  #3056
Raman's Avatar
The exotek are really tight, you need to use oil to break them in. If they are still too tight, switch back to fluorine
Raman is offline
Old 11-20-2016 | 11:34 PM
  #3057
disaster999's Avatar
Regional Moderator
When i built my car the according to the manual, the front right and rear left arms werent swinging smoothly. I had to take out a few of the thinner shims in order for it to operate smoothly. I replaced the shims as needed when things began to break in and developed play.
disaster999 is offline
Old 11-21-2016 | 06:37 PM
  #3058
theproffesor's Avatar
Can anyone tell me if the new Tecra suspension mounts have the lower 05 design like the new 05g blocks, or are they the standard height?
theproffesor is offline
Old 11-22-2016 | 12:05 AM
  #3059
Hi Professor
They are 0.5mm lower. On very hard hits the inserts can crack/pop out. Happened once during outdoor season. Overall very happy
Worst87 is offline
Old 11-28-2016 | 09:40 AM
  #3060
What other drive cup blades fit Tamiya cars. My spool is chewing them apart.
