iCharger 406 DUO Charger
#556
Anyone know where I can buy a new LCD screen for the 406?
#557
this is the place i had to send mine back to for warranty repair to the lcd
http://www.buddyrc.com/ they will probably be able to get you one.
#558
Here's the deal, hope someone can shed some light. I'm getting a low voltage error, usually happens after a few charges, once this happens I can no longer charge that particular pack on the charger, I have to move it to a 306 that I bring along as a spare. I can though charge a different pack and it will work fine for a few charges. I have exhausted multiple charge cables, some I made some bought and they all work perfectly fine with the 306 and other chargers.
So when I get an error i've been moving my lipo to another charger, I've tried at times bringing the lipo back after using it with a 306 to charge on the 406 but not luck. Also keep in mind this is happening on multiple brands of lipo packs from long to short.
have you tried to load the default settings? this is done by holding down the tab/sys button for 2 seconds when powered on. then choose "save and load config" then choose "load defaults configuration"
does the charger give you an error number? this will tell you if you have a battery issue or a power supply issue.
#561
#562
I was going to link a manual for the charger but it looks like they quit making the 406 duo. I don't know if the manuals from the 308 and 4010 will cross over or not. .
http://www.icharger.co.nz/manuals/4010DUO.pdf
http://www.icharger.co.nz/manuals/308DUO.pdf
#563
I have a question. When charging. What are the little bars next to the cell voltages? They kind of look like phone service bars only in green, yellow, and red. Also, they only are shown next to one of the cells. What does this mean?
#565
you can also calibrate the charger. do you have the owners manual? it shows you how to calibrate the charger and error codes.
http://www.progressiverc.com/media/i...o%20Manual.pdf
#566
#567
Does anybody know where I can get a descent hard case for my charger and power supply that doesn't break the bank? Thanks.
#568
Perfect fit for charger, power supply, and resistor bank. Only 15$
#569
http://m.harborfreight.com/11-12-x-7...not%20provided
#570
ebay for a custom modified server power supply 40a $35-$40 with cool carbon fiber sticker!
search icharger power supply
