Tekno RC EB48.3 Thread
#2416
From your setup sheet I'd try 24mm or less front ride height and 1° toe out front.
The camber links are already giving you quite a low front RC compared to the rear RC to a car that, as said, has tons of steer.
My two cents as some says
Edit: Something just went across my mind : what tires are you using ? Sometimes it's as simple a that.
#2417
I'm trying to get a good grasp on wha the pills indicate. Your rear toe is -3.5 degrees right? You posted "0" on your setup sheet, but I figured you just left it blank and didn't actually mean "0" degrees? Am I right?
#2418
#2419
#2420
I tried searching and didn't find the exact answer.
I'm struggling with off power steering (or just getting through a corner tight vs taking it wide)
I used the Joe Bornhorst setup but I have gotten so far away from that that I'm not sure what to call it.
I am using 7/7/5 in the diffs and I believe 425/ 475 in the shocks. The car just won't turn into the corner, I can't comment if its getting out of the corner well because I have to go so slow to setup for the exit.
Any help would be appreciated.
#2422
I have never broken a plastic cap on my NB, I was running plastic on the NB for awhile because I hated the look of the scratched up alum... But haven't had any issues with durability.
Is there much of a difference between emul and vented? I run emul on my sct and vented on my buggies, but don't know the actual differences in performance.
#2423
#2424
Why isn't emulsion recommended for stock setup? When I built my SCT i went emulsion since that is what I used on my Losi SCTE, I never knew the differences between the styles though. I only went it because it's what I knew.
Thanks for clearing up the pros/cons a bit.
#2425
If you look on Tekno's website they have updated setup sheets for outdoor, rough outdoor, and indoor.
#2429
#2430
22Likes
