Turnigy Trackstar Motor Thread >
Like Tree2Likes
Old 12-12-2015 | 06:29 AM
  #211
thecman26's Avatar
I just threw an outlaw 17.5 on my order. Anybody have any experience with these yet? Thanks!
thecman26 is offline
Old 12-12-2015 | 07:09 AM
  #212
Registered User
I only have the 10.5T "stock" and "drift" spec. I've never tried the "modified" and the "outlaw".
Seanzky is offline
Old 12-12-2015 | 09:34 AM
  #213
Devin's Avatar
A bunch of guys are running them here, especially for carpet season. 2 have been no good almost right from the word go. It seems that if they last the first day you are all set, but that's not guaranteed. Going to see if the warranty process is worth the effort.
Devin is offline
Old 12-20-2015 | 08:23 AM
  #214
thecman26's Avatar
My order came in (Outlaw 17.5t) and I am pretty impressed with the quality! This thing has some strong magnets! The motor should run pretty cool with all the cooling holes. Can't wait to get a chance to run it!
Old 12-20-2015 | 08:34 AM
  #215
Davidka's Avatar
It'll run cool if it's efficient. If not, the cooling holes won't help much.
Davidka is offline
Old 01-09-2016 | 09:50 PM
  #216
thecman26's Avatar
After first race with the new Outlaw 17.5t, have to say it's pretty snappy! I have it VERY conservatively geared for a novice racer but can turn laps my T5M runs with a 13.5t or pretty close at least! NICE bang for the buck to be sure! BIG !
Old 01-10-2016 | 03:14 AM
  #217
amospetrie's Avatar
I just ordered trackstar 120 amp turbo and stock 17.5 motor for my losi tt 2.0 buggy to run in Stock class can I get some advice on spur/pinion gearing. Thanks
amospetrie is offline
Old 01-10-2016 | 11:37 AM
  #218
I would start around 70/31 - 70/29.
If the layout is open and flowy and you can keep your speed up, maybe go with a bit larger pinion and/or more can timing.
If the layout is tight and you spend a lot of time getting back up to speed and/or there's a jump that you really need low end grunt for, maybe stay closer to the 70/29 and a little lower timing.
Christophoclese is offline
Old 01-14-2016 | 02:58 PM
  #219
amospetrie's Avatar
OK ty I'm gonna try a 28 it's a small curvy indoor track
Old 09-28-2016 | 12:31 AM
  #220
shannow's Avatar
Hi all,
I have two issues on my trackstar 120A esc gen II paired with a V2 10.5t motor :
Firstly the brakes can't be fine tuned. Whether on the esc program or the D/R on the brakes basically at 90% brakes I have too much brake and at 89% and below is almost doesn't brake anymore. As if there was a huge step difference just at a precise spot. I tried setting the brakes at 100% on the esc and setting up on the transmitter as well as setting the brake power only on the esc. I reseted the esc to factory settings etc.
Secondly and that took me a while to figure the problem as the car would mysteriously shut down while driving :
If I hold the brake trigger on my transmitter for more than 3 seconds the esc shuts down (regardless of the moment in the practice). Any idea why ?
The car is well geared it doesn't go beyond 70° for the motor 45°ish for the esc and 40° for the battery and I have plenty power with a yz2 on carpet with my 10.5t.
thanks in advance
Jonathan
shannow is offline
Old 09-29-2016 | 12:13 PM
  #221
shannow's Avatar
Okay I solved it. I updated the firmware and both problem have gone completely.
The only thing I had trouble with was to connect the thing to my computer.
The correct order for anyone who'd have to go through this is :
-connect esc to the battery
-connect physically the prog box to the esc
-switch the esc on
-connect electronically the esc to the prog box (by entering the esc settings)
-plug the usb cable to the computer and the prog box.
-start the trackstar usb program on your computer.
-it will ask to update.
shannow is offline
Old 10-12-2016 | 04:40 PM
  #222
shannow's Avatar
Got a chance to run it at the club this week. The brake issue I had has definitely gone with the update. But I still have the trigger problem as when I apply the brake more than 3 seconds the esc turns off (even with the car standing still). Any ideas ?
shannow is offline
Old 10-12-2016 | 06:11 PM
  #223
Default 3 sec brake shut down
I have a toro ts120 which share the same hardware design with track star and use slightly different software. Even the toro pc link would work with track star 120a gen ii.
3 sec brake shut down is just a feature of the software. Nothing wrong.
cup racer is offline
Old 10-12-2016 | 06:32 PM
  #224
thecman26's Avatar
Try the ESC thread.
http://www.rctech.net/forum/radio-el...kstar-esc.html
Old 10-15-2016 | 01:51 PM
  #225
its supposed to do that. its a feature of the esc...why are youholding reverse for more than 3 seconds anyway?
Lunchie is offline
