Hex screw for Hitek servo
Which servo do you have? Our 7xxx series of servos and older, use a 2.6mm x 8mm machine thread screw. Our 8xxx and 9xxx series of servos have 3mm x 8mm screws. A-main hobbies has the screws in stock. HPI part number z420 for the 2.6mm. and any 3mm will work.
i called them about this one time and they lacted like it was crazy i wanted hex's.
i have the hitec 9630 sero, the screws seem much smaller and longer than m3 x 8..?
they seem like m2.6 x 12 or something with weird spaced threads, is that not true?
I work for Hitec, the 9360 uses an M3 x 8mm machine thread screw.
The OP was referring to the screw that holds the servo horn on, which is the sizing that i am referring to. We do not make hex case screws.
