Hex screw for Hitek servo
Instead is using the philips screw that comes with it. What size and where to get them?
Should be able to use any 3mm screw with button head.
That's not correct, all the hitec servos I used were m2.6. It's an odd size but available, or do what I did and tap it m3.
Originally Posted by omarwashington
(Post 14690166)
i called them about this one time and they lacted like it was crazy i wanted hex's.
i have the hitec 9630 sero, the screws seem much smaller and longer than m3 x 8..? they seem like m2.6 x 12 or something with weird spaced threads, is that not true? |
M2.6 also holds M2.5.
M2.6 is used in many Tamiya models and M2.5 hex screws are used in bacplates of some nitro engines. |
Originally Posted by lyons238
(Post 14691009)
Originally Posted by Billy T.
(Post 14692019)
I work for Hitec, the 9360 uses an M3 x 8mm machine thread screw.
(Post 14692019)
there's no way those are m3x8 :confused::confused::confused: you guys sent me replacements (great customer service) but im looking to replace them with hex's |
(Post 14692269)
the 4 screws on the outer and the 2 screws toward the middle???
Originally Posted by Andy Koback
(Post 14692113)
What size for the 951 mini servo?
(Post 14692348)
We do not make a mini servo by the name of 951. i know that KO has a 951 servo, but it is not a mini servo, it is a standard sized one.
(Post 14692441)
Sorry for the mix-up...It's a HS-5245 MG.
| All times are GMT -7. It is currently 10:00 AM. |
