Poorly tinned wires
Old 06-14-2016 | 09:05 AM
Default Poorly tinned wires
Could poorly tinned wires cause the car to cog?
Thanks!
Miko1976 is offline
Old 06-14-2016 | 09:21 AM
Thanks!
Cogging is usually caused by bad sensor wire or the sensor itself. Swap out the wire first. (easy part).
Andy Koback is offline
Old 06-14-2016 | 09:50 AM
The motor sensor?
Miko1976 is offline
Old 06-14-2016 | 10:31 AM
Could be you have none.....
A sensorless system has only 3 thick motor wires, a sensored system has as extra a small 6 wire cable connected between motor and ESC.
If you do not have a sensor cable then cogging is quite normal, the motor needs to get some revs before the ESC will detect the rotor position. The motor coils are also the sensors for the ESC but it will not give any signal when the rotor is standing still. Without the position detection at no and very low rpm the ESC is having a somekind own live until the rotation speed is high enough to buld a feedback signal.
With a sensored system there are electronic magnetic sensors which will see the position of the rotor at any time so from zerro RPM the ESC knows how to control the motor.
Roelof is offline
Old 06-14-2016 | 12:18 PM
The motor sensor?
Yes. Like Roelof stated...Your motor may not have one if it's a sensorless system. You'll either see a 6 wire lead from motor to ESC or you won't. This is in addition to the main 3 wires from motor to ESC.
Old 06-14-2016 | 12:19 PM
Geezatec's Avatar
New motor installed? Try recalibrating the ESC, if still cogs Try smaller pinion. Make sure you set your Voltage cutoff correctly.
Geezatec is offline
Old 06-14-2016 | 02:30 PM
Not a new motor. Just put new wires in. Changed the sensor wire & the cogging stopped on load but happens sometimes after landing a jump.
Miko1976 is offline
