-   -   Poorly tinned wires (https://www.rctech.net/forum/radio-electronics/947947-poorly-tinned-wires.html)
Miko1976 06-14-2016 09:05 AM
Poorly tinned wires
Could poorly tinned wires cause the car to cog?
Thanks!
Andy Koback 06-14-2016 09:21 AM
Thanks!
Cogging is usually caused by bad sensor wire or the sensor itself. Swap out the wire first. (easy part).
Miko1976 06-14-2016 09:50 AM
Poorly tinned wires
The motor sensor?
Roelof 06-14-2016 10:31 AM
Could be you have none.....
A sensorless system has only 3 thick motor wires, a sensored system has as extra a small 6 wire cable connected between motor and ESC.
If you do not have a sensor cable then cogging is quite normal, the motor needs to get some revs before the ESC will detect the rotor position. The motor coils are also the sensors for the ESC but it will not give any signal when the rotor is standing still. Without the position detection at no and very low rpm the ESC is having a somekind own live until the rotation speed is high enough to buld a feedback signal.
With a sensored system there are electronic magnetic sensors which will see the position of the rotor at any time so from zerro RPM the ESC knows how to control the motor.
Andy Koback 06-14-2016 12:18 PM
Originally Posted by Miko1976 (Post 14566924)
The motor sensor?
Yes. Like Roelof stated...Your motor may not have one if it's a sensorless system. You'll either see a 6 wire lead from motor to ESC or you won't. This is in addition to the main 3 wires from motor to ESC.
Geezatec 06-14-2016 12:19 PM
New motor installed? Try recalibrating the ESC, if still cogs Try smaller pinion. Make sure you set your Voltage cutoff correctly.
Miko1976 06-14-2016 02:30 PM
Poorly tinned wires
Not a new motor. Just put new wires in. Changed the sensor wire & the cogging stopped on load but happens sometimes after landing a jump.
