Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-15-2016 | 01:17 PM
  #901
what tamiya body is the best for spec racing ?
Quinny45 is offline
Old 05-15-2016 | 11:39 PM
  #902
JD Skyline's Avatar
Maybe you try the raikiri gt body. I'm gonna give that body a try for club racing. Think this body has more downforce then the Audi R8, the new NSX, Brz. I'm not sure, I just have to proof my theory yet. .I ordered it yesterday haha
Otherwise you can try the old nsx bodies.
JD Skyline is offline
Old 05-16-2016 | 11:29 PM
  #903
Josh L's Avatar
61 Impala body, painted to look like an old school Biscayne NASCAR from the 60's era.
Ended up going with HPI Vintage wheels, but in standard OD instead of the vintage series types that would require the use of their spec wheels.
Josh L is offline
Old 05-17-2016 | 10:03 AM
  #904
eR1c's Avatar
Dude! that car is sweeeeeeeet. Nice job, really nice!
eR1c is offline
Old 05-17-2016 | 10:48 AM
  #905
JD Skyline's Avatar
Whoooo that is one awesome lookin 400HP Chevy! Awesome paintjob!! Welldone
Old 05-17-2016 | 12:14 PM
  #906
Originally Posted by steve_pss
Paging Qatmix.. Qatmix please..
Hoping you can assist. I've been upgrading my TT02 based on your awesome guide. As I'm getting back in to this after a 30 year hiatus the help has been very appreciated. As my 17.5 Justock motor is on the way, I decided to go with your gear recommendation of an 82t spur and 49t pinion. Both are 64p. I'm using the high speed set to attach the spur, alum Tamiya motor mount, and used the 16t holes per the guide. The issue is the mesh is def too tight. Not locked up solid tight, but nearly so. Any idea on what might be the issue? I took it out for a spin regardless (I'm dumb for an old guy) and I really love the feel with this gear combo.
I had this same problem running this gear combo and solved it by rotating the motor to the next hole going clockwise while looking at the pinion side of the motor. You should always be able to rock the gears and have just a tiny amount of play between them regardless of the pitch. To much and they strip, to little will be noisy and create drag which will create extra wear and heat up and possibly damage the motor.
microed is offline
Old 05-19-2016 | 08:55 AM
  #907
Josh- Great job man! I love vintage bodies.
Speaking of - why on earth can't a find a decent Aston or Jag vintage body? Been lookin high and low and nothing...
steve_pss is offline
Old 05-19-2016 | 04:18 PM
  #908
eR1c's Avatar
agreed! There are still quite a few bodies I'd love that I've never seen.
Masserati BirdCage
detamaso Pantaerra
Jaguar E type
Porsche 928
Porsche 914
Ferrari 360GTO
..actually there are a lot of cars I'd love to see
eR1c is offline
Old 05-19-2016 | 04:48 PM
  #909
Josh L's Avatar
Thanks guys! I haven't seen one of these done like this before with that body, so it was a chance to be different.
All the lettering and numbers was painted beneath the shell by having a plotter cut out my designs on low tack making vinyl. A bit of work still if you have multi color logo's and all like I had on this one, but it's a very easy and effective way to get great results without needing an expensive airbrush setup for on the quick jobs like this one was.
The local guys at the track really liked it a lot
Josh L is offline
Old 05-19-2016 | 04:52 PM
  #910
Josh L's Avatar
Companies really do need to pay more attention to the old school types like this one and those you mentioned Steve.
I wish they would do some more American bodies like the forgotten 73 chevelles, old novas, mavriks, vegas, montecarlo, even a fox stang... you get the point. They would be awesome to see on a track together, or just to have that old highschool ride a lot of us once had.
Josh L is offline
Old 05-19-2016 | 11:38 PM
  #911
Hasi's Avatar
detamaso Pantaerra
HPI Racing has got the Detomaso Pantera in their portfolio:
#17502 - DE TOMASO PANTERA BODY (F200mm/R210mm/WB255mm)
You'll have to work with offset-wheels but it'll work
Hasi is offline
Old 05-20-2016 | 05:50 AM
  #912
This trick worked like a charm for me. Many thanks! I have the xerun combo in there now, with the aforementioned gearing setup and it's now plenty zippy for my bashing fun. I really need to find some tires (hopefully pre-mount because I'm lazy like that) with more grip. The kit tires and dirty streets aren't a good combo.
Anyone got any suggestions? I don't care about tire wear. If I have to spend money on replacements it's worth it for maxing out the limited fun time I have.
Also, has anyone figured out a gearing combo that might work better on shorter circuits? I run out of street fast by the time I'm up to speed, so I need to find something with more zip and less top end to make things interesting within the bashing confines I have.
Big thanks to everyone for helping out!
Old 05-20-2016 | 03:33 PM
  #913
eR1c's Avatar
Yes, ...all of those cars were present and accounted for in my high school parking lot ...long ago. My first car was almost a Vega wagon w/ a Chevy V8 ...instead in went for a 74 capri which I put a V8 in and made it a true sleeper. My dad had a '701/2 camaro ...I learned to drive on that car. Great times!
...I like the Buick Grand National you have pictured! ...you don't see those very often.
-what do you know! Thanks!!!
eR1c is offline
Old 05-24-2016 | 04:00 AM
  #914
wtcc's Avatar
Tamiya is more focussed on recent racecars or alltime classics (non nascar).
My friends and I lately wanted to race in a more fun way, not having to think about setup and highest performance. Just the driver and his box stock car. We decided for the TT-02 and had a blast last weekend on our first event.
Unfortunately the Raybrig NSX driver was busy. Still the pictures came out quite nice:
We went for Super GT. The bodies are awesome, but it took me nearly a whole day for the stickers only 😂
wtcc is offline
Old 05-24-2016 | 09:30 AM
  #915
JD Skyline's Avatar
Unfortunately the Raybrig NSX driver was busy. Still the pictures came out quite nice.
Those cars are looking great...love to drive the TT02 chassis. And I agree totally on the fun part. How is the handling of the Nissan body?
Have fun!!
