IR Thermometer Temp Gun - what are you using? >
Old 04-18-2016 | 11:30 AM
SuperBoots's Avatar
Default IR Thermometer Temp Gun - what are you using?
What do you guys and gals use to check your temps? How much did you pay? Would you recommend it? Links would be appreciated!
SuperBoots is offline
Old 04-18-2016 | 03:16 PM
General Tools & Instruments Mini Infrared Thermometer from Lowes. Very small and under $25. Works great.
Bforwarned is offline
Old 04-18-2016 | 03:53 PM
SkyRC, wonderfull piece of equipment
Roelof is online now
Old 04-18-2016 | 05:06 PM
HBRob's Avatar
I use something like this.
http://www.ebay.com/itm/DT8230-Non-C...3D162033283213
HBRob is offline
Old 04-18-2016 | 07:46 PM
Geezatec's Avatar
Raytek Mini Temp. Been using since '94.
Attached Thumbnails IR Thermometer Temp Gun - what are you using?-dscn1963.jpg
Geezatec is offline
Old 04-18-2016 | 07:59 PM
dan_vector's Avatar
I am using the Exergen temp gun which I've had for many years. Its a great temp gun but quite pricy. I have been impressed by the accuracy of my fellow racers much cheaper guns including both the Raytek and the skyrc units. The repeatability, i feel, is better on the exergen as the head of the gun fits nicely into the engine head so the position of temp measurement is the same precisely each time. I would buy another exergen rather than a cheaper alternative however thats just me.
dan_vector is offline
Old 04-19-2016 | 08:14 AM
SuperBoots's Avatar
Thanks everybody, I ended up ordering the SkyRC IR thermometer on amazon for $37, I really like that it uses AAA batteries not coin cells. I'll try to remember to update the thread with how I like it!
http://www.amazon.com/SkyRC-SK-50001...ilpage_o00_s00
Old 04-20-2016 | 03:55 AM
dan_vector's Avatar
Good choice. There are a few of the guys here with them and they are all happy with it.
Old 05-12-2016 | 01:09 PM
SuperBoots's Avatar
Just wanted to update and say that I've been using the SkyRC IR thermometer for about a month now and I'm quite happy with it so far.
Old 05-13-2016 | 12:57 AM
Maxximize's Avatar
I'm currently using a Tempgun TG1. Accurate within about 2-3 degrees F and it was only about $20. I've had it for about 2 years now and the factory battery still shows full on the display.
Maxximize is offline
