1/12 forum
I've recently been racing on an extremely low grip surface (not sure what it is - some sort of coated/textured asphalt "stuff").
I've managed to get the car (Tamiya RM01 with most hopups but original chassis) to perform passingly well on a combination of original Tamiya rears and HBR Fronts (other fronts also work with similar performance - Shepard/Enniti Hard, Jaco Purple). However, I want to calm the front down even more to give me a wider setup window. Due to the multi-use nature of the facility where I race, "wet" tire treatments are not permitted.
Try as I might I simply can't get my head around what tire might give me a generally lower front grip, if such a thing exists, given that I am starting from a fairly wide spread tire combo in the first place - any suggestions?
R12-21SS Rear Side Roll Spring (Black/Soft)
R12-21SSS Rear Side Roll Spring (Black/Super Soft)
R12-21SUS Rear Side Roll Spring (Green・Ultra Soft)
R12-21SSU Rear Side Roll Spring (Purple・S-Ultra Soft)
are there other coned side springs for CRC? a lot of CRC side springs are out of stock or low stock and i kind of want to stock up. the side springs i've had on my cars (12th and 10th scale pan) have been on there for MONTHS.
OR have you guys used different side spring holders and side springs for your CRC....
ok the brand new X-ray chassis ready to roll only 24 made 14 left for sale post on here if wanting one.
NEW PRODUCT!
Introducing the new Aluminum Chassis for the XRAY X12 2016! Made from premium 2.5mm thick 7075-T6 aluminum so you can run your stock lower pod plate machined to perfection! Works extremely well on medium-high bite tracks. Generates more traction while at the same time making the car faster and easier to drive.
Features: Anodized Black plate milled down front arms pockets .50 so you can run smaller tires.
•Optimized cutouts for dynamic flex
•Optional holes for direct servo mount to chassis
•15g heavier than standard XRAY carbon chassis
•Lower center-of-gravity
NEW PRODUCT!
Yes, I would Associated black is inline with R12-21SS. I could be wrong.
http://www.windtunnelracingproducts....7a48f3e647a9c9
2991Likes
