Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 01-08-2016 | 07:18 AM
  #4666
Originally Posted by russell73130
is there a upgrade kit to get the et48 truggy to make it the et48.3 truggy
http://www.fiercercsolutions.com/Tek...kit-FRC020.htm
direct link
ezlight is offline
Old 01-08-2016 | 07:55 AM
  #4667
Ilias's Avatar
Hi everyone,
Just a heads up regarding our New Aluminum Stub Axles:
The Tekno RC Aluminum Stub Axles (Part #TKR5070A) are designed to reduce rotating mass as well as unsprung weight without sacrificing strength or durability. After undergoing several months of race proven testing, they meet our high standards for toughness and performance. CNC Machined from 7075 aluminum, then hard anodized for wear, they provide a weight reduction of over 12 grams per pair (over 24 grams for the whole set!). They are a direct replacement for the stock steel stub axles (TKR5070).
Features:
  • 24.4 gram rotating mass reduction.
  • Slightly improved fuel mileage.
  • Increased suspension efficiency by cutting unsprung weight.
  • Three locations for CVA pin placement, extending product life and value.
  • Use with the Tekno RC NB48.3, NT48.3, EB48.3 , ET48.3 and previous generation vehicles.
Thank you for your support!
Ilias is offline
Old 01-08-2016 | 02:19 PM
  #4668
HollywoodRC's Avatar
Just got my hands on a new ET48.3 truggy. I have searched and read every thread about which servo to get. I have always ran Savox servos in all my 1/8th scale buggies without any problems, other than being noisy. Ok, which servo do you guys recommend now. Please be specific, brand and model number, and why.
Thanks in advance
HollywoodRC is offline
Old 01-08-2016 | 02:52 PM
  #4669
vwduud's Avatar
Thanks in advance
I've run the Savox 2273 for almost a year now with great success. Plenty of torque and speed. Cheap enough to not worry as much if it dies (like the $200+ servos of similar specs).
vwduud is offline
Old 01-08-2016 | 04:04 PM
  #4670
SnotRkt's Avatar
I love these Graupner servos in my buggy and truggy!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEWSK
SnotRkt is offline
Old 01-09-2016 | 08:37 AM
  #4671
Default Servos
I started running Savox brushless servos 2274, 2273 and even 2270 because they were mid price range, but had good specs and have been very reliable to me. The 2270 is a little slow for me so I wanted to swap out.
Tried Radiopost 5005S. One was bad out the box. Stripped gears on steering on EB an NB on first race day. Great customer support from Amain, swapped out for Protek 150T because I had no problems with it in NT.
Protek 150T has similar speed specs to Savox 2274, but more torque. We will see how they hold up.
Savox has been very reliable (never had one fail) and works well, just wanted to try something else. Hopefully the Proteks hold up for 3 years too.
qstorm777 is offline
Old 01-10-2016 | 02:54 PM
  #4672
Ok, my Truggy Gurus......I am planning on running a Tekin RX8 with a 1350Kv motor on SMC 6V 4300mah. I always wanted to run 6V in my buggy but didn't because of ROAR. I do not plan on running ROAR with the Truggy. I hope this will be a good combination. What pinion do you guys recommend? The track I will be running , Thornhill, is the largest track in North America.
Old 01-12-2016 | 08:14 AM
  #4673
Numburn's Avatar
That is very uncommon setup. Most people run 4s with higher kv motors. It will be hard for anyone to give a good recommendation. Just have a good selection of pinions when you go to the track and keep an eye on temps. As long as the temp is below 180F you should be fine.
Numburn is offline
Old 01-12-2016 | 09:42 AM
  #4674
I ran the same setup with a 16t pinion on a medium size track.
BJT2814 is offline
Old 01-12-2016 | 09:00 PM
  #4675
Default .
is there a way to change the spindle height? my spindle arm is rubbing when i turn everytime the front wheels come off the ground
jshum610994 is offline
Old 01-13-2016 | 04:30 AM
  #4676
Default Noob
Here's. Pic of the spindle rubbing the front lower arms as the wheels are of the ground. I can't figure out what to do
Old 01-13-2016 | 04:58 AM
  #4677
WonTonsChicken's Avatar
Reduce the droop by about 1mm or so
WonTonsChicken is offline
Old 01-13-2016 | 05:09 AM
  #4678
Yeah, what Wonton said. When you reduce the droop to whats in the manual or using Joe's setup it shouldn't rub. Also, you can flip the screw.
Old 01-13-2016 | 06:02 AM
  #4679
Default .
Thanks guys I had no idea. Any idea where I can find joes setup?
Old 01-13-2016 | 06:51 AM
  #4680
vwduud's Avatar
http://www.teknorc.com/tekno5/wp-con...MediumBite.pdf
http://www.teknorc.com/tekno5/wp-con...t%20Cancer.pdf
vwduud is offline
