Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 01-07-2016 | 08:26 AM
  #26506
(0000000000)'s Avatar
Originally Posted by Callahan_88
Hello!
Im thinking of buying an M05 mini cooper!
which tire to Buy?
And what options are needed?
Want to ceep it at low cost som we can ride and have some fun.
First thing I would recommend is ball bearings. Second thing I would recommend is some Tamiya S-grip tires. The rest is up to you and how you intend on using the mini.
(0000000000) is offline
Old 01-07-2016 | 08:36 AM
  #26507
sakadachi's Avatar
So what do you guys do with the unused plastic bushings? I have a whole jar of them
Wish I had this jar back in the early 80's when I had no money to buy bearings.
sakadachi is offline
Old 01-07-2016 | 08:59 AM
  #26508
OSherman's Avatar
you can make a Tamiya Bead necklace..
OSherman is offline
Old 01-07-2016 | 09:19 AM
  #26509
Gravity Dodger's Avatar
Originally Posted by monkeyracing
I'm not looking for perfection. A single rung above mediocre will suit my needs.
Interesting thing about running laps last night - the track was so incredibly grooved in, I was running clean tires with no sauce at all. Even with glued sidewalls and first row of tread, traction roll was present on turn one, at the end of the straight. I'm impressed!
Our local track just installed the new crc rug and after a three day event traction was insane, so much so that EVERY class had ca on their front tires and even the sedans and 1/12th scales were still occasionally traction rolling. I had read about how the guys were handing the rug in Cleveland so I refrained from saucing and just cleaned on occasion during practice and ran dirty during the quals. The car felt extremely loose at first but quickly came in and drove great.
I also figured out my wheel hop issue, too low of a ride height. I raised ride height from 4 to 5mm for the event and problem solved. Still curious about this one as I've seen minis run four and lower with no hop but that was the only change I made over the weekend?
Gravity Dodger is offline
Old 01-07-2016 | 09:31 AM
  #26510
monkeyracing's Avatar
Some guys actually use them in lower speed vehicles like trail rigs. Plastic bushings don't mind getting wet.
monkeyracing is offline
Old 01-07-2016 | 09:53 AM
  #26511
sakadachi's Avatar
That's true, very smart indeed!
Old 01-07-2016 | 01:32 PM
  #26512
eR1c's Avatar
Originally Posted by Callahan_88 View Post
Hello!
which tire to Buy?
Where do you plan on running your M05? -Parking lot fun, or competitive racing?
Also, have you considered the M05 VII?
tire choice as well as setup recommendations will be different depending on your intended use.
eR1c is offline
Old 01-07-2016 | 05:31 PM
  #26513
Callahan_88's Avatar
I built a completely stock M05 with plastic bushings and all. For just having fun, the only 2 mods I recommend are:
1) Stiffer diff (check out how to do the MR diff aka monkeyracing diff), it is very cheap and easy to do.
2) Oil dampers (Tamiya CVA super mini #50746) will work, with yellow short springs front, red short springs rear.
My kid drives this M05 and he is having a ball. GL
Great have to take time to read this whole thread!
Callahan_88 is offline
Old 01-07-2016 | 05:37 PM
  #26514
Indoor carpet only!
Old 01-08-2016 | 12:40 AM
  #26515
Nice little track. Now we got something to base a setup on. What type of motor are you going to run? My setup is based on the HPRT setup, but a slightly stiffer suspension and harder tires (M-grip) because of the unrestricted motor rule where I currently am.
Old 01-08-2016 | 10:37 AM
  #26516
eR1c's Avatar
..are you running slicks on carpet?
eR1c is offline
Old 01-08-2016 | 08:17 PM
  #26517
sakadachi's Avatar
Mine are almost slicks.
http://www.rctech.net/forum/members/...-front-bar.jpg
Made a custom stabilizer for my SabreFD Mini.
The rear bar is from a M05.
http://www.rctech.net/forum/members/...ni-m05-bar.jpg
Thing is finally dialed in after trying 4 different springs and these bars today after hours of trial and error last weekend.
Old 01-09-2016 | 12:52 AM
  #26518
howardcano's Avatar
Type A slicks on the front with S Grips on the rear worked great for me on carpet.
howardcano is offline
Old 01-11-2016 | 06:05 AM
  #26519
hprt's Avatar
That is the go-to setup for the M06 on high grip carpet.
For M05, use S-grips all around.
hprt is offline
Old 01-11-2016 | 07:41 AM
  #26520
If your car is hopping when you lower it, then your spring preload is too high... I prefer running zero preload... You'll probably need to lengthen your shocks...
My M03.2 (BERT edition) also used to hop, until I reduced my preloads....
bertrandsv87 is offline
