Tekno ET48 Thread
#4652
If you're a racer, you can finish a race with a bent hinge pin. That's a little more challenging with a broken suspension arm or hinge pin holder.
I've read where some have purchased 4mm drill blank material in order to achieve a stronger hinge pin. I have yet to hear whether that did in fact solve the problem of bending the hinge pins in a big crash. I also haven't heard if a stronger hinge pin now moves the force to a weaker link. In other words, did they trade straight hinge pins for broken suspension arms or hinge pin holders.
Please let us know what you find out when you make your own hinge pins.
#4654
#4655
#4656
I am not sure, but I think the hinge pins of my other cars have got bent less in the past. It could be easily be solved, either by using better steel, or they just use some spring steel, which is more flexible. I will cut some spring steel into pieces to get that solved. I dont't think that due to better steel the arms will break...
I remember that someone advised to use hinge pins of a brand I can't remember, as they have better steel.
An other improvement would be to use inserts made of rubber, instead of plastic.
My LRP/ZCar Pro Truggy had rubber-inserts, which have lasted for ages.
@WonTonsChicken: you should be fine with filling the diff as advised in the manual. I have heard that the Silicone Oil expands when it gets hot, so you have to leave a "gap". Others say to fill it up completely, but I never did that (just almost full).
#4659
I'm running a 1900 buggy motor and it's a beast. The motor comes off at 140 degrees after 20 minutes. If I were buying another motor for this truck, I would look into a 1700 motor.
#4661
The ProLine Enforcer body has been popular with a few people I know..
#4665
Buggy motors work fine. I would recommend 1900kv or lower. The 2100 is a little too much for truggy and could have heat issues.
38Likes
