Mamba Max Pro Calibration Issues
#16
Solved.
Using a Spektrum SRS4210 with AVC. You cannot calibrate any ESC until you calibrate the AVC receiver.
The solution was found at Tekin's website.
Here is the link:
Unforunately I have not reached the amount of posts needed to post the link. Just PM me.
Alternatively you can use the search terms "spektrum tekin calibration" in google
Here is the link:
https://www.spektrumrc.com/ProdInfo/..._Manual_EN.pdf
You must do this whether using AVC or not. If you are NOT using AVC, you must use two bind plugs: one in the BIND port, the other in the DISABLE port. After performing the TX/RX calibration, the standard ESC calibration will work normally. Fought this one all day trying to calibrate a Mamba Max Pro with this rx and a Spektrum DX4C.
#17
Correct, you MUST perform the TX/RX calibration on page 8 of the SRS4210 receiver manual BEFORE attempting ESC calibration. Here is the link to the manual:
