Mamba Max Pro Calibration Issues >
Old 11-24-2017 | 03:15 PM
  #16
n10cities's Avatar
Originally Posted by Mavtop
Solved.
Using a Spektrum SRS4210 with AVC. You cannot calibrate any ESC until you calibrate the AVC receiver.
The solution was found at Tekin's website.
Here is the link:
Unforunately I have not reached the amount of posts needed to post the link. Just PM me.
Alternatively you can use the search terms "spektrum tekin calibration" in google
Correct, you MUST perform the TX/RX calibration on page 8 of the SRS4210 receiver manual BEFORE attempting ESC calibration. Here is the link to the manual:
https://www.spektrumrc.com/ProdInfo/..._Manual_EN.pdf
You must do this whether using AVC or not. If you are NOT using AVC, you must use two bind plugs: one in the BIND port, the other in the DISABLE port. After performing the TX/RX calibration, the standard ESC calibration will work normally. Fought this one all day trying to calibrate a Mamba Max Pro with this rx and a Spektrum DX4C.
n10cities is offline
Old 11-24-2017 | 04:41 PM
  #17
You realize you're responding to a 2 yr. old thread, don't you?
Andy Koback is offline
