The AE FActory Team B44.2 Thread >
Old 07-30-2015 | 04:10 PM
  #8251
Does anyone know if the 44.3 gear slipper can be put into the 44.2?
justin payne is offline
Old 07-30-2015 | 05:33 PM
  #8252
Jerm13's Avatar
Its not a gear slipper. Its a gear diff. And yes but additional parts are required to get it to fit, like the rear center shaft.
Jerm13 is offline
Old 07-30-2015 | 05:57 PM
  #8253
Cool.. I figured it would go in there
Would you happen to know exactly what parts to get, So i dont have to guess.
Thanks.
Old 07-30-2015 | 06:10 PM
  #8254
RobsRacin's Avatar
Regional Moderator
I think you will just need #9940,#9941, and #9949, but I could be wrong
RobsRacin is offline
Old 07-30-2015 | 06:22 PM
  #8255
Jerm13's Avatar
Thanks.
Im in the middle of converting my .2 to a .3. I downloaded both manuals and started writing down the different part numbers for the entire drive line But I plan on running with the 2 pad VTS slipper and not the diff.
I know for a fact the rear center drive shaft is specific for the center gear diff P/N 9596 and I think you may need the bearing inserts P/N 9940. Along with the center diff and spur gear obviously...
Jerm13 is offline
Old 08-06-2015 | 10:20 PM
  #8256
Nat Maniac's Avatar
Id like to keep my centre slipper but change to f & r gear diff. Has anyone done this and could confirm exactly what parts ate needed?
Nat Maniac is offline
Old 08-07-2015 | 08:25 AM
  #8257
You need the complete gear diffs, input pinion gears, and input shafts.
Krio is offline
Old 08-07-2015 | 10:39 AM
  #8258
Nat Maniac's Avatar
Thanks. What about diff cases?
Old 08-07-2015 | 10:46 AM
  #8259
dbowen's Avatar
Diff cases and bearings are the same.
dbowen is offline
Old 08-07-2015 | 10:48 AM
  #8260
Razathorn's Avatar
You'll need to sand down the peg in the diff case to accept the gear diffs.
Razathorn is offline
Old 08-11-2015 | 06:25 AM
  #8261
JDe's Avatar
JDe
Is there any speculations or new on a new 4wd from AE in the near future?
JDe is offline
Old 08-11-2015 | 07:03 AM
  #8262
RobsRacin's Avatar
Regional Moderator
My personal opinion is we see one in the later half of next year
Old 08-11-2015 | 01:41 PM
  #8263
Nat Maniac's Avatar
I did a little research and its more than $175 to build front and rear gear diff if you want to keep your ball diff intact as an optional drop in...
Old 09-30-2015 | 07:21 PM
  #8264
Hey guys just picked up a used B44.2 on here and am actually enjoying it more than my B5m in stock class. Was wondering if there was an easier (read: more affordable) way to be able to run shortys than with the Schelle conversion?
EDIT: Reading back a couple pages it doesn't appear to be possible, unless someone knows of something I missed?
drewbagel423 is offline
Old 09-30-2015 | 07:53 PM
  #8265
RobsRacin's Avatar
Regional Moderator
Nope, not enough room from the center slipper back.
