Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 09-09-2015 | 08:19 AM
  #3046
yzracer758's Avatar
Team Tekin
Originally Posted by Vega1975
Hi,
When I am running my temp are close to max all the time. I usually measure 74-78 degrees on my T8 and around 50 degrees on esc. Some time I actually pass 80 degrees on T8 and that is not ok.
I gear 15/46 at the moment but will try gear up to 16/46 to see.
What else can I change with Hotwire to reduce temps? What is maximum temp esc can handle?
I use software version 250
Drag brake: off
Current limit: 95
Push control: 5
The rest is defualt.
Thanks in advance
Which vehicle is this in and what T8 motor are you running?
yzracer758 is offline
Old 09-09-2015 | 10:04 AM
  #3047
Sorry!
Mugen mbx7r eco with 1900kv
Vega1975 is offline
Old 09-09-2015 | 10:29 AM
  #3048
rcgod's Avatar
Sorry!
I would gear up to a 16 and reduce current limit to between 60 and 80. 80c degrees isn't THAT hot maybe at the upper end of what you want to see but not going to melt down the motor. I run a 1900 in my 7r eco and 15 pinion seems ok for small tracks but 16 works better overall for me and temps aren't any higher. I also run timing profile 1.
rcgod is offline
Old 09-09-2015 | 10:57 AM
  #3049
Wouldn't gearing up on the pinion make it work harder? I was just reading the RX8 manual and it was saying damage would occur if you keep thermaling it, which is 220°F. 50°C is quite a distance from that.
Calde315 is offline
Old 09-09-2015 | 12:01 PM
  #3050
Randy_Pike's Avatar
Team Tekin
Gearing is very track and surface dependent. If you have a larger track and or a track that has a lot of wheel spin, gearing up can help bring temps down.
Randy_Pike is offline
Old 09-09-2015 | 12:32 PM
  #3051
rcgod's Avatar
Keep in mind this is a general statement and not always true but has worked for me. Hot esc cool motor=gear down. Hot motor cool esc= gear up. A lot of guys think that gearing down is the solution to a hot motor but sometimes if you gear up the motor is working in the more efficient rpm range and wheel spin is reduced so motor temps go down. Plus with a taller gear you have more wheel speed available to help keep the nose up when jumping.
rcgod is offline
Old 09-09-2015 | 06:38 PM
  #3052
Hoese37's Avatar
One of the most common problems I see when people run a multi pole motor is being under-geared. Its very common that when you have a motor heat issue, you are spinning the motor at a higher RPM and not running in the powerband.
Hoese37 is offline
Old 09-09-2015 | 07:07 PM
  #3053
Default Gearing
I don't know if this is the right place to ask, but I'm going to throw it out there. Running a RX8 Gen2 3 deg of timing and T8 1900 in my buggy. 10 min main, probably 85 degF or so out. ESC ran about 142, motor about 175. Should I gear up 1 tooth or leave as is? The temps are according to datalog.
qstorm777 is offline
Old 09-09-2015 | 08:30 PM
  #3054
I'd leave it...... Tekin has stated in the past; that under race conditions and time you are fine with temps below 200*f
freebird is offline
Old 09-10-2015 | 06:34 AM
  #3055
Default Bearings
A totally different question. I replace my bearings quite often in the T8 g2. What kind I'm bearings do you recommend?
I guess that also effect the heat!?
Vega1975 is offline
Old 09-10-2015 | 08:32 AM
  #3056
I wondering if gearing up one more tooth on the pinion will take me over that 200 deg temp on motor?
Old 09-10-2015 | 08:38 AM
  #3057
yzracer758's Avatar
Team Tekin
The bearings that come in our motors and the same ones we offer as replacements is a high quality ABEC 5 bearing. We have not seen any reason to spend the extra money of expensive ceramic bearings.
Old 09-10-2015 | 05:37 PM
  #3058
vandalzzz's Avatar
Scary images about undergearing and lack of cooling at EB48:
Rotor blasted, ruined sensor board, wire has been desoldered from motor' B-post. Luckily ESC survived, and motor' stator too (no shortcuts b/w phases and body, and no Ohm spikes between phases), so only -84$ instead of 160 or 320 (for whole system).
After 2 mins after 'finish' i had 215F at the motor, blasted right before finish line after 8min final. Actually i've overheated it (a bit) before, so no complains about this. The only question to Tekin team is: is it possible to make sensor board w/o elements exposed to rotor?
vandalzzz is offline
Old 09-11-2015 | 01:01 AM
  #3059
I have done that twice also.
How often do you change bearings in T8?
How many hours between replacement do Tekin rekommend if the temps are ok?
Vega1975 is offline
Old 09-11-2015 | 11:10 PM
  #3060
Hitokiri_2000's Avatar
I must admit I have ceramic bearings in my T8 1900kV motor. They were already installed when I bought a Durango DEX 408 V1 buggy second hand with the T8 installed. I Saw no reason to change them. But then again I only use the buggy for light bashing. It's mostly a display item.
Hitokiri_2000 is offline
