Like Tree12Likes
Tekno NB48
Old 06-22-2015 | 05:13 AM
  #3406
Apco1's Avatar
A new or highly updated buggy is expected. How soon? Don't know.
Apco1 is offline
Old 06-22-2015 | 05:52 AM
  #3407
speedy2's Avatar
m2c
speedy2 is offline
Old 06-22-2015 | 09:10 AM
  #3408
adrictan's Avatar
Originally Posted by speedy2
Can someone explain what so many holes on the wing will do for the car?
adrictan is offline
Old 06-22-2015 | 09:31 AM
  #3409
Ryan said he was looking to decrease the down force a bit. He felt the back of the car was over stuck.
MX304 is offline
Old 06-22-2015 | 09:52 AM
  #3410
Reduction of down force and weight.
masher81 is offline
Old 06-22-2015 | 10:42 AM
  #3411
speedy2's Avatar
+ more speed
speedy2 is offline
Old 06-23-2015 | 08:48 PM
  #3412
Plus the car is more agile in the air. Derek ran the same thing at Nats and The King of Kings race 2 weeks before. There was a top speed difference down the back straight and through the sweeper at Nats. This is a tuning option and comes in handy on high traction tracks.
gasser is offline
Old 06-24-2015 | 11:50 PM
  #3413
Because RACECAR!
... On a serious note as others stated, to reduce downforce for high traction tracks. Helps add more steering in high speed sections as Lutz thought the rear was over stuck to the surface and struggled to get it to corner as he liked. I personally run mine at max downforce because I run a much smaller track and I prefer to jump with the nose low.
jviolet10 is offline
Old 07-08-2015 | 06:54 PM
  #3414
I wanted to ask at what point do you replace chassis? Should Chassis be replaced after 3 gallons. To me, I inspect chassis at rebuilds about every month and check for cracks, bend, droop screw area and F/R wear into the A-D Blocks. I think the chassis should be the longest lasting part on any kit. I know if you run on an abrasive track than chassis would need replacing. Your thoughts drivers!
paposwing14 is offline
Old 07-08-2015 | 09:50 PM
  #3415
Carter Flotron's Avatar
Generally when the rear of the chassis measures 1-2mm is when I replace. There's no real time span, it just depends on the tracks you run on and your driving ability.
Unfortunately that isn't really how it works in the 1/8th market as it is now. RC has some of the weirdest norms of any cars in the world in that they are actually designed with the acceptance that the chassis is going to contact the ground for a good amount of the time its driven (more than you think...jump faces, landings, bumps, even around fast corners). If you setup your car to never touch the ground then it will handle poorly, its just kind of how it is.
Thankfully companies are beginning to wise up and are making chassis with integrated steel skid plates that can be replaced, which makes the chassis last far far longer than a one piece unit. By far the best I've seen of this is the M2c chassis line. No other company has thought to put in a front skid where the chassis bends as well, which is absolutely genius.
Carter Flotron is offline
Old 07-09-2015 | 06:03 PM
  #3416
Very good Carter, Great option Tekno can adopt; Skids on Chassis!!
Old 07-10-2015 | 06:28 PM
  #3417
Any word on a release of the nb48.3?
turtle189 is offline
Old 07-10-2015 | 07:08 PM
  #3418
FastPete's Avatar
Aprox 3-4 weeks
FastPete is offline
Old 07-12-2015 | 09:32 AM
  #3419
Originally Posted by FastPete
Aprox 3-4 weeks
Thanks fast Pete.
Old 07-20-2015 | 01:13 AM
  #3420
Exclamation Tekno delivers new and improved NB48.3 1/8 buggy
http://www.neobuggy.net/2015/07/20/t...48-3-18-buggy/
NB48.3 New Features:
Completely redesigned suspension geometry
Revised chassis
New front arms
New rear arms
New front and rear 7075 CNC aluminum shock towers
New extra long shocks for increased suspension travel
New tapered 4 x 1.8mm shock pistons
New clamping spring perches with captured shock boots
New rear hubs
New trailing front spindles and spindle carriers
New V2 hinge pin braces and inserts
Low profile wing mount
Revised bumper for increased ground clearance
New straight turnbuckle rod ends
New left and right hand threaded shock mount screws
New easily adjustable droop screws
Revised shock standoffs for easier droop measurement
New brake linkage for easier adjustments and more consistent braking
New revised 46t spur gear
New brake pads and discs for unparalleled durability and consistency
Longer rear sway bar for more consistent traction
Updated setup sheet for improved handling
TRiN is offline
