Like Tree256Likes
Tamiya TRF419
Old 06-07-2015 | 08:50 AM
  #1681
RedBullFiXX's Avatar
Originally Posted by TryHard
http://www.thard.co.uk/much-happenings/
A few thoughts from the day and past few racing events...
Pooooooowwwwwweeeeeerrrrrr!
Awesome write up as usual Mr T.
RedBullFiXX is offline
Old 06-07-2015 | 08:53 AM
  #1682
One thing to note is regarding the rear wheelbase. If your using the kit suspension blocks (X/F) then try 2.5mm. This is equivilant to using 2mm with X/E blocks. This is due to the arms being swept back a little more and lengthening the wheelbase, hence needing less shims to get the rear wheels in the same place.
HiH
Ed
Cheers, I was just going to ask about that. I'm just setting my car up in RC crew Chief ATM.
Qatmix is offline
Old 06-11-2015 | 08:02 AM
  #1683
blf
I know this is for the experts talking set up, but new to TC's and built a 419 (great build) and just testing on some tennis courts here and the car is fantastic right out of the box.
I just have a grinding type sound that will be heard on a full stop to full throttle start (and a tiny bit of "bog" almost like turbo lag on a real car) but feathering the throttle from standstill will not produce this and will give me smooth accel to speed.
Sorry for the noob question and please direct me to the right place to ask if I'm off base here --- just thought you guys know this chassis
blf is offline
Old 06-11-2015 | 08:46 AM
  #1684
Which motor and ESC are yo using ?
Old 06-11-2015 | 08:53 AM
  #1685
JimmyMac's Avatar
Are your belts loose? If they are too loose the belt could be skipping when you hit the throttle or the brakes hard.
JimmyMac is offline
Old 06-11-2015 | 08:54 AM
  #1686
blf
13.5 VST2 pro and R10.1
blf is offline
Old 06-11-2015 | 09:05 AM
  #1687
blf
Interestingly enough, just took it out again after cool down and NOT exhibiting it at all from full throttle at stand still ------ so its something caused by heat?
Car is just incredible BTW
blf is offline
Old 06-11-2015 | 10:34 AM
  #1688
From: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Check your motor sensor wire.
lagcisco is offline
Old 06-11-2015 | 10:56 AM
  #1689
blf
All good there
blf is offline
Old 06-11-2015 | 11:26 AM
  #1690
JimmyMac's Avatar
Gearing? Motor timing? Blinky mode or turbo/boost?
JimmyMac is offline
Old 06-11-2015 | 01:01 PM
  #1691
blf
41 pinion with the 111 spur and all stock settings other than that
blf is offline
Old 06-11-2015 | 01:06 PM
  #1692
Raman's Avatar
If it happens again test with different sensor cable. I know you said it's fine.. Those wires are delicate and may appear fine.. But a bad wire can cause a lot of problems.
Raman is offline
Old 06-14-2015 | 02:16 AM
  #1693
Simmi's Avatar
Has anyone tried the 42290 Carbon Chassis 2mm thick with steering bridge and steering brace?
I want to buy
Simmi is offline
Old 06-14-2015 | 04:13 AM
  #1694
Have an event coming up later this week - round 2 of the AOC run by Scotty Ernst.
Car prep finished tonight, new motor and new batteries has meant new wiring. Quite possibly my neatest job yet. Umino eat your heart out
I want to buy
Tempted, as I run on a super low grip track normally. And it is quite cheap.
cplus is offline
Old 06-14-2015 | 04:49 AM
  #1695
TryHard's Avatar
Good luck. Shame I can't be there, but I am shooting for a Japan trip for later in the year to AOC at Yatabe instead!
Had a day of practise at IMCC, suffice to say, car felt really really good on track, but hard to gauge the pace as was the only mod. But consistency was good, so happy with progress in that department
Ed
TryHard is offline
