Tekno NB48
#3196
Changing the fuel line often is important. Any and all of them we have used over the years tend to soften and get limp over time, some sooner than others. Having the line submerged in fuel in the newer style tanks speeds up this process. I have actually seen the part of the line inside the tank collapse to the point no fuel could pass through it.
#3197
Another big name on the Tekno team. Man the squad is looking good.
http://www.neobuggy.net/2015/03/17/t...er/#more-55648
#3198
#3201
#3202
If everyone send these guys emails asking them to make us a nitro body I'm sure they will. So, please take time and shoot them an email....
http://shop.leadfingerrc.com/contactus.sc
#3203
#3204
http://www.amain.com/reedy-flat-li-poly-receiver-battery-pack-7.4v-2300mah/p268576
http://www.amain.com/lrp-vtec-2s-li-poly-hump-receiver-battery-pack-7.4v-2700mah/p291957
#3205
All the lipo humps are very similar and I've noticed the same performance from all brands I've had such as protek, lrp, reedy, trakpower and others. They may all have one but the LRP is hard case.
#3206
Graham, the LRP 2700 hump receiver pack I'm currently using is a soft case style.
#3207
Cool, thanks for the input fellas!
Next question would be, how much run time would I be looking at for say, a 2700mAh battery? Or, would this just be a good time for me to get a voltage checker?
#3208
I use the protek electric switch which has visual queue of low voltage. Typically I can go an entire day (practice, 3 qual, 30 main) on one, but I don't push it and charge at least once for saftey.
#3209
SMC or protek will both work fine in my opinion. I have the SMC in my NT48 and protek in the NB48.
#3210
It may "look" like a soft pack but if you look through the clear blue wrapping you'll see hard plastic case around the center portion. It's not a hard case in the traditional sense like a stock or shorty but it's better than no case.
12Likes
