Sensor Wire Tester
Old 02-19-2015 | 12:29 PM
1mrdad's Avatar
Default Sensor Wire Tester
Does someone make a sensor wire tester? I have a number of them that I would like to check. I only own 1 car, and because of the location of the esc, and the way the sensor wire is plugged in, it is not practical to check them in car.
1mrdad is offline
Old 02-19-2015 | 02:41 PM
http://www.racing-cars.com/pp/Manufa..._RC/CR162.html
http://www.atomikrc.com/products/motor-sensor-tester
Roelof is offline
Old 02-19-2015 | 07:38 PM
If you have a multimeter you can just check continuity from end to end of each wire in the sensor cable.
nitrousdave is offline
Old 02-21-2015 | 10:29 PM
cokemaster's Avatar
I have the Core-rc tester. Recommended. Connect it directly to your motor with the sensor wire and test both. No external battery needed.
http://www.amain.com/core-rc-sensor-...widget/p213536
cokemaster is offline
