-   -   Sensor Wire Tester (https://www.rctech.net/forum/radio-electronics/863710-sensor-wire-tester.html)
1mrdad 02-19-2015 12:29 PM
Sensor Wire Tester
Does someone make a sensor wire tester? I have a number of them that I would like to check. I only own 1 car, and because of the location of the esc, and the way the sensor wire is plugged in, it is not practical to check them in car.
Roelof 02-19-2015 02:41 PM
http://www.racing-cars.com/pp/Manufa..._RC/CR162.html
http://www.atomikrc.com/products/motor-sensor-tester
nitrousdave 02-19-2015 07:38 PM
If you have a multimeter you can just check continuity from end to end of each wire in the sensor cable.
cokemaster 02-21-2015 10:29 PM
I have the Core-rc tester. Recommended. Connect it directly to your motor with the sensor wire and test both. No external battery needed.
http://www.amain.com/core-rc-sensor-...widget/p213536
