Go Back  R/C Tech Forums > General Forums > Rookie Zone
Best electronics for a Axial Yeti? >
Old 02-12-2015 | 02:57 AM
Lightbulb Best electronics for a Axial Yeti?
Hi,
I'm about to buy an Axial Yeti kit - What would be the best electronics? (I've got a Futaba 3PK), also any recommendations for engine and ESC? I've seen others are using HobbyWing?
Cheers
hobbykicks is offline
Old 02-12-2015 | 03:44 PM
MOmo's Avatar
The included 3150KV 4-pole brushless motor - This from the Axial RTR version of the Yeti.
With that said- any 550 motor should be adequate for what you need. It is a larger vehicle so the 550 (which is more of a SC style motor vs a true 1/8th scale motor) should be enough power.
They recommend 2 or 3s lipo for power- so any compatible battery should be fine.
You recommended HW-
http://www.hobbywing.com/product.asp...&subclassid=46
http://www.hobbywing.com/product.asp...&subclassid=51
This seems like a great combo Esp. when you factor the WaterProof factor (thought I personally never really can trust things like that, so I don't usually go play when its wet.... but that's me. )
Battery- there are plenty of options, anything 2s or 3s should suffice. See what fits your budget.
Hope this helps.
MOmo
MOmo is offline
Old 02-13-2015 | 05:29 AM
Thanks, this is super helpful, I see this one is sensor-less, what are the advantages of going for a sensor based engine? Does it matter for a crawler?
HK
Old 02-13-2015 | 08:21 AM
TIME MACHINE's Avatar
HK
In my opinion, sensored is the only way to go if you are ever going to do any low speed crawling. The motor and ESC "talk" to each other which results in a much smoother throttle and overall better responsiveness.
With a sensorless system, you would more than likely experience "cogging" which is like a stutter type of feeling and is no good for a slow crawl.
TIME MACHINE is offline
Old 02-13-2015 | 12:29 PM
Okay I'm probably looking at something like the XERUN SCT Competition system then.
Thanks!
Old 02-18-2015 | 09:11 PM
Thanks!
I run that combo in my Tekno sct and have no complaints, it will be on its second race season.
seanhawk is offline
Old 02-19-2015 | 12:11 PM
I'm planning to run a Toro 150A and an SMC 1900kV sensored motor. Not sure how well the Skyrc stuff will work, but I've read/heard good things. I'm a Castle fan normally...
MaxxWrecker07 is offline
