Go Back  R/C Tech Forums > General Forums > Rookie Zone
Best electronics for a Axial Yeti? >
Old 02-12-2015, 02:57 AM
Lightbulb Best electronics for a Axial Yeti?
Hi,
I'm about to buy an Axial Yeti kit - What would be the best electronics? (I've got a Futaba 3PK), also any recommendations for engine and ESC? I've seen others are using HobbyWing?
Cheers
hobbykicks is offline
Old 02-12-2015, 03:44 PM
MOmo's Avatar
The included 3150KV 4-pole brushless motor - This from the Axial RTR version of the Yeti.
With that said- any 550 motor should be adequate for what you need. It is a larger vehicle so the 550 (which is more of a SC style motor vs a true 1/8th scale motor) should be enough power.
They recommend 2 or 3s lipo for power- so any compatible battery should be fine.
You recommended HW-
http://www.hobbywing.com/product.asp...&subclassid=46
http://www.hobbywing.com/product.asp...&subclassid=51
This seems like a great combo Esp. when you factor the WaterProof factor (thought I personally never really can trust things like that, so I don't usually go play when its wet.... but that's me. )
Battery- there are plenty of options, anything 2s or 3s should suffice. See what fits your budget.
Hope this helps.
MOmo
MOmo is offline
Old 02-13-2015, 05:29 AM
Thanks, this is super helpful, I see this one is sensor-less, what are the advantages of going for a sensor based engine? Does it matter for a crawler?
HK
Old 02-13-2015, 08:21 AM
R/C Tech Elite Member
TIME MACHINE's Avatar
Trader Rating: 74 (100%+)
HK
In my opinion, sensored is the only way to go if you are ever going to do any low speed crawling. The motor and ESC "talk" to each other which results in a much smoother throttle and overall better responsiveness.
With a sensorless system, you would more than likely experience "cogging" which is like a stutter type of feeling and is no good for a slow crawl.
TIME MACHINE is offline
Old 02-13-2015, 12:29 PM
Okay I'm probably looking at something like the XERUN SCT Competition system then.
Thanks!
Old 02-18-2015, 09:11 PM
Thanks!
I run that combo in my Tekno sct and have no complaints, it will be on its second race season.
seanhawk is offline
Old 02-19-2015, 12:11 PM
I'm planning to run a Toro 150A and an SMC 1900kV sensored motor. Not sure how well the Skyrc stuff will work, but I've read/heard good things. I'm a Castle fan normally...
MaxxWrecker07 is offline
