Charge leads?
Old 01-02-2015 | 11:18 PM
R1Joel's Avatar
Default Charge leads?
Can I use these to charge with? Change the male to a female and it will work? Is there a difference between charge leads and battery leads?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
R1Joel is offline
Old 01-03-2015 | 03:55 AM
Those will not work. They are for the battery, not the charger. The balance lead is a bullet connector. There is no way to connect that to the charger.
msbytes is offline
Old 01-03-2015 | 11:18 AM
While I'm not completely sure how you are wanting to use it, if your lipo has inboard tube ports, your charger has a Traxxas connector (or you change it), and the white balance connector is the right type for your charger (doesn't say for sure but perhaps a common JST-XH type), then sure it will work.
Dave H is offline
Old 01-03-2015 | 02:15 PM
R1Joel's Avatar
Thanks for the replies. I was just hoping to plug that into charger output ports. I don't need the balance wire as the batteries have one.
R1Joel is offline
