Charge leads?
Can I use these to charge with? Change the male to a female and it will work? Is there a difference between charge leads and battery leads?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
While I'm not completely sure how you are wanting to use it, if your lipo has inboard tube ports, your charger has a Traxxas connector (or you change it), and the white balance connector is the right type for your charger (doesn't say for sure but perhaps a common JST-XH type), then sure it will work.
