Like Tree12Likes
Tekno NB48
Old 12-15-2014 | 06:38 AM
  #2971
Originally Posted by MattDub
No, doesn't give more rear traction. Actually less rear straight line traction. What it does is make the rear of the car more predictable under hard acceleration when exiting a corner. Too much rear toe can make the rear of the car behave oddly in corners and lose traction. It's something we've recently revisited and it made quite a difference for those who drive hard.
I have started taking some rear toe out of mine too after installing the lrc rear block.
MX304 is offline
Old 12-15-2014 | 10:40 AM
  #2972
CoryD's Avatar
Default Center Diff
So what's the consensus on how to get the center diff out in the most efficient/fastest way?
Later,
CoryD is offline
Old 12-15-2014 | 10:46 AM
  #2973
Later,
Take the 6 screws on the bottom of the chassis out. Then the 4 on stop of the diff housing. then it opens open by pivoting the center braces around the brake linkage.
masher81 is offline
Old 12-15-2014 | 11:32 AM
  #2974
Graham11's Avatar
^ what he said.... except you also need to dettach the linkage, I recommend doing this at the servo horn end(flat head and lock nut end) of the brake linkage as opposed to removing a collar, this way you dont have to worry about resetting your brakes.
When removing the 6 screws be cognizant of the fact that the 2 going into the brace are slightly longer than the 4 going into the diff mounts.
Graham11 is offline
Old 12-16-2014 | 06:43 PM
  #2975
Just bought an nb48 and eb48.2 switching from mbx6,
I scanned through the posts briefly but do not have time to sift through all the pages, is there anything that is truly needed when putting these kits together? Or will everything pan out fine going by the instruction manual on both?
Thank you !
spencey820 is offline
Old 12-16-2014 | 07:00 PM
  #2976
FastPete's Avatar
Thank you !
Aluminum servo horn for steering, otherwise your golden.
FastPete is offline
Old 12-16-2014 | 07:19 PM
  #2977
Thank you sir
Old 12-17-2014 | 07:15 AM
  #2978
Graham11's Avatar
Thank you !
instructions are second to none... so nothing to worry about there, if there are extra shims in with your diffs then use the dark ones, this was an update to the kit.
In terms of parts/hop ups, nothing is needed other than the aluminum servo horn which tekno sells for all three spline counts. If you really want to buy something you can get the aluminum center drive shafts, tini shock shafts and delrin shock inserts... all which are a nice upgrades but by no means a necessity, maybe best for your next rebuild. For tuning, obviously some springs but also the LRC rear brace. For the NB48 specifically, I recommend the 10 degree offset brake cam, not sure if this was a running change to the kits or just an option part but it will really help with brake setup.
Graham11 is offline
Old 12-17-2014 | 07:19 AM
  #2979
Hoese37's Avatar
Later,
Front two out of the top plate, rear two out of the diff mount under the car. Pull back and lift up. You will need to remove the brake linkage as well. Just 4 screws.
Hoese37 is offline
Old 12-17-2014 | 07:21 AM
  #2980
Graham11's Avatar
the rear center diff mount piece is connected to the rear center brace, how do you remove that without also removing the screws from the brace? And doing it that way you will have to reset your brake linkage everytime, no?
Graham11 is offline
Old 12-17-2014 | 07:27 AM
  #2981
Hoese37's Avatar
Lol I was thinking of it backwards. Ive done it with just those 4. I usually just pull the screw out of the front brake linkage lever, and pull the horn on the servo.
Hoese37 is offline
Old 12-17-2014 | 07:42 AM
  #2982
Graham11's Avatar
i guess it could work but id rather not reset my brakes and also sounds like it would be a pain to get the diff back in and get the drive shafts to line up but obivoulsy do whatever works for you. I like to do the 6 bottom screws and the flat head and locknut on the servo horn and pull the whole assembly out, this way I can check and adjust the brake pads while I am in there and often times I am cleaning the chassis at the same time so removing the whole thing makes that easier as well.
After a race day I pull the fuel tank and clean and inspect, then engine and pipe by removing the four cap head screws attaching engine to mounts and clean and inspect(i do not remove the engine with the mounts still attached, again because I dont want to re-mesh everytime, although always check the mesh either way) and then I pull the center diff and brake assembly and clean and inspect. With the center diff removed I can then check the feel of the front and rear diffs and decide whether they need to be serviced.
Graham11 is offline
Old 12-18-2014 | 07:04 AM
  #2983
Hey has anybody driven and xb8 2014 and then switched to Tekno? How do they compare is Tekno getting ready to release a new car ? I like X-ray ,stable easy to drive and almost indestructible but they change cars to often to keep up . But with all that said X-ray was way more stable then my mbx7 so I am not looking to go back that way . To the slippery back that Neva seems planted . Any help would be great .
Eastside777 is offline
Old 12-18-2014 | 10:19 AM
  #2984
I have not owned a XB8 but have helped a friend with his and spent a lot of time driving his. The XB8 is pretty amazing but the tekno is just as good. The driving style is different though and may take some getting used too. The way the 2 cars tune is different as well. It will take some time to adjust but I certainly think you will be happy with a NB48. As far as I am aware there is no plan for a new car anytime soon.
masher81 is offline
Old 12-18-2014 | 11:33 AM
  #2985
Bortzilla's Avatar
Does anybody know what brake rotors Mr. Lutz has on his NB48 in this video?
+ YouTube Video
https://www.youtube.com/watch?v=t65WgtA0OJI
Bortzilla is offline
