Tekno RC EB48 Thread
Anyone ever experience Tekno wheel nuts skipping a thread when tightening up their wheels? It's the strangest thing but on one wheel recently fell off in a qualifier so I went to tighten it a little extra and it skipped a thread and loosened up a bit. After looking at both the axle threads and nut threads they both appear fine although there is some slop with them. I also thought it must have been the 17mm hex slipping inside the wheel but that is not the case either making all this seem very strange
. I will replace the hexes and wheel nuts to see if it makes this issue go away, just wondering If I'm the only one who experienced this?
. I will replace the hexes and wheel nuts to see if it makes this issue go away, just wondering If I'm the only one who experienced this?Tech Adept
Is anyone else using the LRC brace in addition to the Delrin LRC pills (sold by PROTC3) on the front and back of their EB-48's with success? I am currently running my EB-48 with both of these options with the camber links in the inner upper hole on the towers front and back and it has never been more dialed at the indoor track I race on.
On a side note when I tried these same options on my SCT410 it was completely crap, and didn't have any of the handeling attributes the EB-48 has on the same track. Just curious to see if any others have tried this out yet on either vehicle and noticed an improvement?
. Both the threads in the suspect wheel nut and hub appeared to be perfect visually, but when they were threaded together you could notice there was some lateral slop
causing the issue.
been installing this kit this week! happy early Christmas to me. I just installed the center diff and noticed that it will spin easily for about a 1/4 turn and then it becomes hard to turn... any reason for this that I need to look at? I already shaved off a little of the plastic brace above it as it was rubbing, then I took that plate off just to make sure. I don't want to keep going with the build for the sake of taking things back apart to fix it... thanks!!
ifso
Put the top plate back on and let it rip...the spur will set itself after the first run....the top plate almost acts as a thrust control
took a closer look and it seemed that one of the screws in the differ was slightly backed out enough to rub... cranked it down now it's good to go... my first build, forgive me.. ha!
Our local track Adventure RC raceway is clay and has tons of grip but can get dry and loose really quick at times. I also move the back camber link to the inside top and no other changes other than tires and it makes all the difference in the world. I haven't tried the front yet as I didn't feel it was needed. I now have 3 EB48.2 buggies. I really like this buggy.
Any ideas on MBX7R-Eco vs EB48.2? Still debating which one to get.
to be honest I don't think you can go wrong with either one.
One of the fastest guys here ran mugen this summer, another fast guy ran tekno. From what I could tell when cornering as I wasn't fast enough to be in there main was that the tekno in my eyes seemed to have more corner speed, the mugen seemed to be a bit more consistent through the rough stuff, basically a slight more planted rear end. However, we are not talking light years here and it could have been more due to setup, etc. And we run on conditions that when they dry out get very very loose, and very very very very rough lol.
I can't speak on the eco7r as I don't believe it has been released yet. However, I still feel that the tekno is a far better value as well a better quality kit. The tekno build is one of if not the best in the biz.
Taking my brand new eb out today for its very first run around the track in stock setup. Can't wait, hopefully I can be at least close to the laps I run with my rc8 v4. One thing I did notice though when the build was all done is there is a large amount ofvsteering slop in the left wheel, cant seem to work out why. Any thoughts?
I don't remember there being any slop when I built mine (a v1). Double checked all the steering linkages, etc, I assume?
2Likes
Cant wait for some pics.
