NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 10-04-2014 | 09:18 AM
  #11941
Cobraracing, I pmed u. Thks
aonz84 is offline
Old 10-04-2014 | 03:11 PM
  #11942
Benzaah's Avatar
Originally Posted by COBRARACING
Hi are you using the program port or the rx port to program?Dont forget orion where you swapped from uses the sensor port to program and the hw use to use the rx port to program on the 2.1v now v3.1 has its own port .
I was a HW user back when you had the V2.1. Yes the Orion works differently like the old 2.1. I did read the manual. I had connected the speedy to just the program box prior to it bricking and it would connect and update settings with the box fine. As it was a mod profile there was no fwd/Br/zero profile, so I then hooked up the PC to change from Mod to stock when it bricked. Initially it connected to the PC and I could see all settings to upgrade. When I tried to update profiles I hit trouble.
Benzaah is offline
Old 10-05-2014 | 12:40 AM
  #11943
You didn't need to change the firmware to go blinky - I think it's profile 2 on the shipped firmware....Or alternatively, you just set all timing settings to 0 in the mod profile, and it blinks.
MattW is offline
Old 10-06-2014 | 11:57 AM
  #11944
Hi,
Been playing with the speedo quite a bit. I can feel the difference when changing endbell timing, Boost timing and FDR. Turbo timing I play with and can not really feel any difference or certainly not to the extent of the other adjustments. Is turbo a small change?
Running HW V10 13.5 motor.
adyb is offline
Old 10-06-2014 | 12:49 PM
  #11945
TB03Racer09's Avatar
You can run up to 64 degrees/steps of total timing, anything you add after that will not be counted. Turbo is added at the end so maybe you already have too much boost and endbell timingd
TB03Racer09 is offline
Old 10-06-2014 | 01:35 PM
  #11946
AlanHall's Avatar
Do you have to use the PC to change profiles?
AlanHall is offline
Old 10-06-2014 | 01:57 PM
  #11947
Nope, can do it from the setting box.
MattW is offline
Old 10-07-2014 | 01:46 AM
  #11948
TryHard's Avatar
To expand on what Matt said, plug the program box into the program port (not rx lead), and turn it all on.
Wait for the speedo to boot up, and press the 'enter' button. Then you'll get an 'connecting esc' message.
When you've connected the esc, it should pop up with a statement about profile, before going into the settings. When in the settings, hit the 'r/p' button (which will then display which Profile your in), and then 'value' to change the profile. 1 is the default mod profile, and 2 is the default blinky profile (although as has been mentioned before, the esc will blink in any profile, if both the boost and turbo values are set to zero). You'll need to a scroll through all the profiles if you miss one though.
Additionally, if you keep hitting 'r/p' instead of 'value', that will take you to the data logging info, of motor and esc temp, minimum voltage, and max rpm.
HiH
Ed
TryHard is online now
Old 10-07-2014 | 12:18 PM
  #11949
Hi,
Am I right in thinking that if you have Turbo engaged by "full throttle" and delay "instant" that the Turbo Timing value i.e. 20,000 rpm is not taken into account?
adyb is offline
Old 10-07-2014 | 03:39 PM
  #11950
TryHard's Avatar
Originally Posted by adyb
Hi,
Correct, although the turbo rpm value is only taken into consideration if the turbo engagement is set to 'throttle and rpm' or 'rpm only'. The delay doesn't factor in that (as it relates to how long after full throttle is reached that the turbo starts to apply)
Old 10-08-2014 | 09:16 PM
  #11951
Dang, mine crapped out doing an upgrade. It said update failed try again. Now when I connect it to the program box it doesn't connect, although the lights are on.
I bought this thing on eBay, it came in a white hobbywing box with no halligraghm. It looks real. Could it be fake? How can I get this fixed? I own 5 hobbywing esc's.
sealander is offline
Old 10-09-2014 | 03:43 PM
  #11952
Madulla's Avatar
Angelo. Do people need to upgrade to 3.2 if they are only running blinky? Does 3.2 only change to boost by taking out the RPM range? I got my 1s esc back now and was thinking that since I was running Blinky there is no need to even try to upgrade to 3.2.
Also in TC mod 80x36 carpet track with a 5.0t. The software is telling me the Max I should run is 10 turbo and 0 boost. Is this what people are running? I thought the boost should be around 30 atleast...
Madulla is offline
Old 10-09-2014 | 06:13 PM
  #11953
Fred_turbo's Avatar
i agreen Madullam,the boost should be around 30 atlest
Fred_turbo is offline
Old 10-10-2014 | 01:07 PM
  #11954
Just wanted to say I just updated two older v3s (not 3.1s) without a single problem. I've also updated two v3.1s (one 120a and the other a stock spec) and they're all running great.
I'll never buy any escs except HW!
hyujmn is offline
Old 10-11-2014 | 05:01 PM
  #11955
Fred_turbo's Avatar
I want to konw which motor collocation the Hobbywing ESC?
