Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 10-07-2014 | 06:10 AM
  #22171
Originally Posted by [email protected]
Being new to tamiya mini do a ball diff in m05 inprove the perfomance of the car (speed wise) thanks.
Thank u .
yok45@msn.com is offline
Old 10-07-2014 | 11:21 AM
  #22172
I just got a new 21.5 motor (killshot) and it has unlimited timing adjustment. How much timing are you guys running with the standard gearing?
jha07 is offline
Old 10-07-2014 | 11:26 AM
  #22173
shmit 1's Avatar
Using 20t pinion. I run max timing, 80*. Make sure you use a fan like an R1, or something comparable.
shmit 1 is offline
Old 10-07-2014 | 12:12 PM
  #22174
Just a thought on tires. I have my m05 running and handling well my main issue is the front tires spin alot on full throttle acceleration i use tamiya s grips on carpet was wondering if moving to tamiya slicks would help my acceleration traction? And also if it would effect my handling at all? If its gonna make me start traction rolling or something bad i'd rather just deal with the spinning tires. I use a gear diff with 50,000 cst and the orca spark system as per wcics rules up here in canada. Will the slicks give more or less steering. Oh and i have the sidewalls glued on the fronts aswell as the first 1-2mm of tread. Thanks
Justin33 is offline
Old 10-07-2014 | 12:27 PM
  #22175
axle182's Avatar
Hi Justin, I am assuming you mean the inside wheel is spinning on corner exit. Your issue is the diff oil, it needs to be much thicker. I run (from memory its been a while since ive worked on it) 500,000 mugen oil in a 3 racing gear diff. Ive heard of others running 1m also. The CA sounds perfect on the front, and another idea is to run alot of sauce on the front tires. the CA will stop the car from rolling over. S Grips are the tire of choice. A tires are not as quick IMHO.
axle182 is offline
Old 10-07-2014 | 12:29 PM
  #22176
axle182's Avatar
Justin something else I forgot to mention, is running a hard rear sway bar and no front bar. The idea is to lock down the front of the car, making both wheels work to accelerate the car.
axle182 is offline
Old 10-07-2014 | 12:38 PM
  #22177
Thanks.
How hot does it get at 80 degrees with a fan?
And what's the highest timing you can run safety without a fan?
jha07 is offline
Old 10-07-2014 | 12:41 PM
  #22178
I've tried both slick A and B, and S-grips have more grip.
jha07 is offline
Old 10-07-2014 | 01:01 PM
  #22179
Originally Posted by jha07
Thanks.
Too hot.
Depends somewhat on the track layout. Back it down to about 75 on a big track and a little more on a tighter track. Besides on a tighter track, less timing is a bit better. It is still better to run a fan tho.
As always, just my opinion. Others may disagree.
Granpa is offline
Old 10-07-2014 | 01:19 PM
  #22180
Smile
So you are basically running 21.5t boosted in your minis..... No wonder they're so fast...
bertrandsv87 is offline
Old 10-07-2014 | 01:38 PM
  #22181
monkeyracing's Avatar
I set up my new V2 that way and found the car much more tail happy than than V1. Not sure why. Need to find the balance between ride height and pre-load.
Bert! I almost missed you. How's things under the bridge?
monkeyracing is offline
Old 10-07-2014 | 01:46 PM
  #22182
Old 10-07-2014 | 01:55 PM
  #22183
Smile
Mini has gone boosted... Should the motor timing be regulated ??? I think so..... 45degrees max !!!! What do you say????
Old 10-07-2014 | 02:20 PM
  #22184
I was more referring to just in a straight line i get tons of wheel spin it actually exits corners pretty well with very little tire spin. I find running too think of oil in the gear diff takes away to much steering
Justin33 is offline
Old 10-08-2014 | 12:31 AM
  #22185
marcos graveyar's Avatar
On our carpet over here M-Grips are what work best.
marcos graveyar is offline
