Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 09-03-2014 | 01:56 AM
  #21961
sosidge's Avatar
3Racing SAK-65A should be the part.
sosidge is offline
Old 09-03-2014 | 07:17 AM
  #21962
jdawg81's Avatar
Thanks but this part seems to be not available anywhere anymore. It seems the only way to replace the outer joints is to buy a new gear diff.
jdawg81 is offline
Old 09-03-2014 | 08:37 AM
  #21963
Billh's Avatar
Default TCS power plant
What is a good 21.5 setup for TCS racing?
Billh is offline
Old 09-03-2014 | 08:38 AM
  #21964
rc_square24's Avatar
Is the rear overhang of the mini cooper (original) body supposed to fit very tightly with the rear bulkhead on the M05? It's basically touching and deforming (slightly) the body on mine.
rc_square24 is offline
Old 09-03-2014 | 09:02 AM
  #21965
Please don't take this the wrong way, but there is no way to answer your question. There simply is not enough information provided.
First, you didn't specify what car and what option parts you have. It's helpful to know what kind of track you'll be racing. Set ups are different.
Besides, there's been hundreds of posts related to your question. If you'll do a little research, I'm sure you'll find your answers. In fact, Calvin posted a good base setup not too long ago. I've posted my base setup several times, but it's been awhile and it was for the M03.
Also, too often, guys will just do part of the setup and not have success. All setups are integrated with one part making the other part work. If you just take parts of it and leave off parts, it may wind up being worse than what you have.
Granpa is offline
Old 09-03-2014 | 09:14 AM
  #21966
Billh's Avatar
I searched 21.5 but did not see any brands listed. The car is a m05 and a m05 pro v2. Race track is my driveway for now but I hope to make the TCS race in Connecticut . I'll search some more tonight. Thanks
Billh is offline
Old 09-03-2014 | 09:40 AM
  #21967
OSherman's Avatar
It's hard to incorporate a complete setup when you only receive a portion of the information... That's one thing I've learned with minis lately... There's some thing that they just won't divulge. The Diff setting is an intragal part of a mini setup. And the interpretation if shock length and rebound is very eluding depending on which shock tower mounting location you are using, particularly in the front.
You really have to dive in and just start trying things.
OSherman is offline
Old 09-03-2014 | 09:43 AM
  #21968
Billh's Avatar
I'm sorry guys I'm just looking for a esc and motor setup not complete car my bad.
Billh is offline
Old 09-03-2014 | 09:47 AM
  #21969
OSherman's Avatar
I personally use the ORION speedos (original R10 Stck Spec, two years old) that was salvaged from my old touring car. Had a HobbyWing Just Stock but it didn't have enough brakes for my driving style...
As far as motor, you can't go wrong with an R1Wurks 21.5.... Period
OSherman is offline
Old 09-03-2014 | 11:57 AM
  #21970
Orlando, I'm howling in protest. When have I ever been less than open with you. I've even had you drive my car to see if you liked it. The problem here was that we were driving different models of the M chassis.
You're right about the diff tho. You do have to adjust the set up to the diff. The problem here is that no 2 diffs seem to come out the same even if identical in construction. You build it to a certain "feel" and hope like hell it works.
Granpa is offline
Old 09-03-2014 | 12:34 PM
  #21971
OSherman's Avatar
Comment wasn't directed in any particular direction. Just in general because of the fact that no two diffs can be built the same, yet the diff setting is crucial. To a point of which you can not simply 'tell some one'. Build it, try it, build it again is what's needed. So although you apply someone's setup there is still a lil fudge factor you will not have..
You can get close, but will never be 'spot on'.
In a class like mini where it's taking some guys 45min to apply glue to the sidewall ever so precisely to get that optimal deflection/rigidity ratio oh so perfect, every minute detail is critical.
OSherman is offline
Old 09-03-2014 | 12:46 PM
  #21972
OSherman's Avatar
Yes Grandpa... You have been very open with your insight and knowledge. And I greatly appreciate it.
OSherman is offline
Old 09-03-2014 | 12:52 PM
  #21973
OSherman's Avatar
On the flipside... No single individual outside of myself knows all the precise inner workings of my setup, but I have shared and scattered every detail thruought the mini community. It's like a scavenger hunt, pick up the pieces.
I'm sure I'm not alone.
Why? I barely have time to setup mine own and sometimes forget some of the details... True story. Ha.
OSherman is offline
Old 09-03-2014 | 12:56 PM
  #21974
Yes you did Orlando. Thanks for the oil weight tip.
Danny R
fx35rc is offline
  #21975
But are you supergluing the hinge pins yet?
Difuser is offline
