Tamiya mini cooper
Damn its always that pesky loose nut behind the wheel
Can anyone tell me the part number for the Slick tires not the 60d Radials?
Mike
I'm going to assume that the steering buckle is the rod going from the servo arm to the steering linkage and is on a M05. If it isn't just ignore the following.
A common mistake is that some don't realize is that the angle between the rod and the servo arm should be 90 degrees. Too often people think the center point is when the servo arm is at 90 degrees to the servo case. You need to remove and replace the servo arm or servo saver so that it is 90 degrees to the rod and not to the servo case. This means that the servo arm/servo saver will be forward of the center line of the servo case. If the servo arm/servo saver is properly positioned on the servo, the rod will need to be as much as 10mm or more shorter. This is something I see often and is not just an error a newbie makes. I've seen this on cars of experienced Mini racers.
Set ups change from track to track and surface to surface. That's why you should develop a base set up that you can work from and adjust. I do next to no carpet racing, but have a solid base setting for carpet. Tweaking that gets me to competitive times in short order in spite of my relative inexperience on carpet. I like running on carpet, but absolutely hate the "fuzz".
After reading Grandpas post about the steering rod/servo-horn angular-positioning i tried applying his advice. Oh what a difference it makes. Prior to I had to set more radio EPA on one side just to get equal turning radius at full lock. It's the small things that count and make our lives a lil easier. Thanks for the tip.
And yes, I see a LOT of minis setup how mine WAS. Ha
Yeah, Mike, I'll admit to being a little on the compulsive side. However, the better the driver, the more anal he is about how his car is put together. Better tighten those nuts cause we can't have your nuts falling off and bouncing down the track after you.
There aren't too many conditions where the Tamiya Type A or B slicks would be the best tire to use. Lots of better choices, unless the club rules force you into those tires.
Well, I guess even Tamiya doesn't know how the servo saver should be angled. Kit boxes and web pics show the off centre angle, M05 and M05v2 manuals show the 90 degree angle...
I'll be trying the off centre angle, also got sick of the EPA settings. Never to old to learn...
Hey folks!
So I read around the last 10 or so pages of this thread. Some great info. I'm sure there's more if I dug a little deeper.
I was wondering if I could get some quick opinions. I am building a new M05V2 kit on RCSoup.com (it's not up yet). This class is new to me, and nobody around here runs them (except R/C Kinetics in Troy, NY and their program is relatively new). So my sources for mini experts locally are limited, although I've had great input from a couple folks.
Anyways.. a small group of us are "buying in" to this class of racing as a potential new class to renew the fun factor of racing. Last carpet season was brutal on the wallet with everyone chasing the best chassis, motor, etc for oval racing.
While road racing isn't necessarily huge in our area, we do have CRC (I'm in upstate NY btw). Others are oval only, but I'm curious if they would be willing to throw down some quick barriers on oval day and let us play (Walts and Buddyboys already do this for Short Course on the same track, ours just wouldn't need jumps).. The tracks aren't huge, but neither are the cars.. So, it may be a simple track?
Either way.. there are 3-4 carpet tracks within 1.5 hours from me. None of them currently run Minis, or anything close for the most part. I don't like being the guy that's always starting a new class, but other than Legends, there is no entry level/intermediate, fun, competitive, cheap class.. but with nationally recognized TCS rules, and tracks like Kinetics, Madness, Brownies, and others within 6 hours.. it makes sense to stick close to those rules for traveling purposes.
Does anyone have any recommendations for gaining interest in a new class, in a relatively untapped market? We have a few folks open to the idea, but have not began to advertise our interest yet. We want to see how many racers are interested before asking any tracks to offer such a class.
Opinions? Also, with the V2 out, should we stick to the 50c lipo precedent that Brownies seems to be imposing on racers? I'm ok with it, CRC is my source for lipos and they offer a couple cost effective options, including a shorty (if those are legal?) and VTA pack.
I'm assuming the class will be a mix of m05/m06 cars setup for either 21.5 blinky and silver can.
No clue on tires for the carpet. I'm going to try S-Grips with Soft inserts my first time out on the V2 (setup as LWB w/ JCW body- which I read is not ideal for short tracks, but it's what I have).
Thanks, and sorry for the long post.
Best advice to help it grow - keep it simple and cheap. Here's the most stripped down set of rules I can think of.
- Any Tamiya M Chassis (M01-M06)
- Cheap spec BL system or silver can
- Any mini rubber tire/hop-up/body/diff (Stock gear ratios! No cheater gears!)
- 2S hardcase batteries
- Set a minimum weight
Here's why this works.
- Allowing all chassis gives freedom of choice, but it will naturally filter itself down to one or two that work.
- Speccing the motor will prevent motor wars or motor of the month crap. Keeps it cheap.
- Opening up option for hop-ups, etc, gives choice and, in most cases, the price of entry into aftermarket hop-ups, tires and bodies is WAY cheaper than Tamiya. (Although the quality of some Tamiya stuff is superior)
- Allowing all diffs shuts up the whiners and people running stock ones will find a way to lock them up anyhow. Keep stock gear ratios, though. The available "speed gears" are garbage.
- Hardcase batteries. Safety!
- Minimum weight. Helps filter out cheaters or, as they'd describe themselves, smart, crafty, innovators or "engineers". Go for something between 1220-1300g.
Jim
Jim
295Likes
