The AE FActory Team B44.2 Thread >
Old 06-03-2014 | 08:34 PM
  #7786
mschumi101's Avatar
Default Selling B44.2
Well, really hate to see this go. But its just not a popular class in my area anymore. Will have to switch over to 2WD
Here is the link if anyone is interested:
http://www.rctech.net/forum/r-c-item...er-spares.html
And just for you guys (I always like pics of the cars ) some final pics before pulling the electronics- I thought it was one of my best wiring jobs on this car to date! Looks clean, no where near the driveshaft, easy slipper access, etc.
mschumi101 is offline
Old 06-04-2014 | 01:38 AM
  #7787
1fastPIRATE's Avatar
thanks for the suggestions on the diff rebuild, I guess ill go ahead and get new ceramic balls and new rings, ill wait on the gear dif because I know absolutely nothing about them. cant wait till my parts come in! im ready to see it look like a car again!
also mschumi101 good luck with sale! looks like it was well taken care of.
1fastPIRATE is offline
Old 06-04-2014 | 10:45 PM
  #7788
Wild Cherry's Avatar
Just put the black sway bar on the front tonight, get to try tomorrow.
Wild Cherry is offline
Old 06-05-2014 | 07:57 AM
  #7789
Jcozz's Avatar
Just got my rpm arms installed. Super beefy!!
Jcozz is offline
Old 06-05-2014 | 02:25 PM
  #7790
nEoNidas's Avatar
Default ?
new to the associated family. will 22-4 wheels and tires work on the b44.2? or is the offset way off? please advise. thanks.
nEoNidas is offline
Old 06-05-2014 | 03:36 PM
  #7791
Waflet's Avatar
The fronts won't work. The b44 uses a 9.5mm hex that nobody else uses. The rears, however, are the same 12mm hex almost everyone uses, including the 22.
Waflet is offline
Old 06-05-2014 | 08:02 PM
  #7792
nEoNidas's Avatar
Thanks bud, appreciate the info.
nEoNidas is offline
Old 06-05-2014 | 11:23 PM
  #7793
Got to run the car with a front sway bar (black) today.
Really surprise me how it performed.
Thought it would smooth out the steering a little.
Not..lol
Instead it brought more tip end & over all steering.
So not gona be using as I do not need more steering .
Old 06-06-2014 | 10:55 AM
  #7794
TCS_FUN's Avatar
Does anyone make a front 12 mm hex for this car??? I'm sick of buying AE specific rims.
TCS_FUN is offline
Old 06-06-2014 | 01:59 PM
  #7795
nEoNidas's Avatar
Default point in the right direction
could you guys point me in the direction of what durango diffs to get, and what other parts i will need to make the modification for the steel diffs. seems to be a worthy upgrade, unless you guys can talk me out of it.
nEoNidas is offline
Old 06-06-2014 | 02:27 PM
  #7796
mschumi101's Avatar
Short answer: No. If you are looking to get front wheels that will work across a variety of vehicles, it doesn't really work because each vehicle has a different offset rim. There are many brands that make rims to fit the front of the B44. AKA, Jconcepts, Proline, DE racing, and Associated to name a few.
Old 06-06-2014 | 04:09 PM
  #7797
timaay!!'s Avatar
You want to get the gear diffs for a dex410. You will also need to get a machined pinion gear and proper bearings to fit the diff cases. Bugle boy is an option, or TSchulz3 on here. (I got mine from him). It will probably cost $100 for the machined parts, diffs are $40 apiece. It's pricey, but soo worth it!
timaay!! is offline
Old 06-07-2014 | 04:10 AM
  #7798
My car is dialed with ball diff's....
dan-o is offline
Old 06-07-2014 | 09:32 AM
  #7799
Who needs a gear diff ?
Sounds like a expensive mistake to me..
Old 06-07-2014 | 10:55 AM
  #7800
Not sure how they would fit... But the new HotBodies D413 uses 12mm hubs on the front. (they are also able to use a 9.5mm hex that is included in the kit also so the b44 guys can switch and not worry about pitching good tires because of the new kit.)
The hex has a 5mm inside diameter, and is designed to ride on the inner race of the bearing.
Just thought I'd share if it can help~
http://www.hpiracing.com/en/part/112744
erevo1*16 is offline
