The AE FActory Team B44.2 Thread >
Old 07-04-2014 | 12:15 PM
  #7936
BRSracing's Avatar
I have never seen AE discontinue a popular car without a new one within weeks away. With TLR Kyosho etc having new cars no way they give up the market until next spring. If so not good. B44.2 is too popular to leave a whole in the lineup.
BRSracing is offline
Old 07-04-2014 | 12:38 PM
  #7937
TomErickson's Avatar
And especially in a Worlds level class.
TomErickson is offline
Old 07-04-2014 | 10:42 PM
  #7938
Thumbs up
Originally Posted by Wild Cherry
Will be a while either way, probably by next spring..
Hearing
Alloy chassis that's in-between the 44.1 & 44.2
Ball diff
Improved gears & main driveshaft cups
VTS slipper
If that were the case they wouldn't discontinue it now. They would wait and try to get out all the old stock kits they could.
The recent price slash and now discontinuing would suggest they are clearing space for a new product. Ie. You stop having your parts supplier producing the obsolete items and ramp up production new items. Unless you are leaving that market. With competitors releasing new buggies recently and the revitalization of 4wd buggy I would highly doubt AE is leaving the scene.
B5 is out and running now. B55 should follow. Then if they plan on redoing the sct's most likely that follows afterwards.
robbie_gtc is offline
Old 07-05-2014 | 08:05 AM
  #7939
Wild Cherry's Avatar
Tech Legend
Robbie
B55 ?
What's that extra 5 standing for ?
5 months from now ? Lol
Believe the .3 will just be another C4 .
Something to get by with until the B54 arrives.
Wild Cherry is offline
Old 07-05-2014 | 03:24 PM
  #7940
Wink
Robbie
B55 ?
B44 was double the drive wheels of the b4 so b55 double the drive wheels of the b5
I don't think it they would use.3 business. Who knows....
It wouldn't make sense to wait long for release info. I wouldn't be surprised if there is some announcement before the end of the month. (sits hopefully)
Old 07-06-2014 | 10:50 PM
  #7941
mashimarowu's Avatar
Anyone know of an easy way to set the slipper? The spring is so stiff that its hard for me to screw the nut any further.
mashimarowu is offline
Old 07-07-2014 | 05:53 AM
  #7942
Scionara05's Avatar
Ok I used the search and cant find anything I just picked up a b44.1 from a local I traded him old equipment I dnt use anymore what is a good gearing for a 10.5 blinky mode esc for a starting point I have the 81 spur but also have other smaller spurs if need be any help would be great
Scionara05 is offline
Old 07-07-2014 | 07:47 AM
  #7943
Tech Legend
remove the slipper from the car.
Take the spring and compress it flat with a pair of pliers.while your compressing the spring coat the threaded shaft with blue Lock Tight and let dry.
reassemble with about 1/4 in of thread showing past the slipper nut.
Install inside car , can readjust the slipper with a 5/64 driver by sticking it inside the hole in the side of slipper nut.
If you are using brand new pads ?
Will need to break them in a pack or two ,then readjust the slipper to get good acceleration with out it being locked up tight.
Old 07-07-2014 | 09:29 AM
  #7944
Default rear arms
Which arm is stronger ,that will break less?
Asc9764 stock arm
Asc9781 hard arm
Airride is offline
Old 07-07-2014 | 09:34 AM
  #7945
Tech Legend
They are both similar in strength.
Bigger difference in the handling .
Most use the plastic version.
Old 07-07-2014 | 10:33 AM
  #7946
fq06's Avatar
Asc9764 stock arm
Asc9781 hard arm
Get the RPM arms if you want the most durable front arms and regular rear arms... not hard
fq06 is offline
Old 07-07-2014 | 11:44 AM
  #7947
The hard arms doesn't have flex so on impact it will break easier ?
Airride is offline
Old 07-07-2014 | 11:46 AM
  #7948
fq06's Avatar
Yes, less flex, more brittle. Should have better performance on high bite tracks at the expense of being easier to break.
RPM arms and nothing else for the front if you are concerned about durability.
fq06 is offline
Old 07-07-2014 | 11:50 AM
  #7949
Tech Legend
The hard plastic was not designed for extra strength.
Its extra stiffest compared to the plastic& offers another tuning option
On higher traction surfaces Hard arms are used.
IM I guess nobody noticed the improved durability
of the plastic B44 front arms.
Old 07-07-2014 | 11:59 AM
  #7950
fq06's Avatar
I haven't noticed because I haven't had to replace my RPM arms yet
fq06 is offline
